12-05-2021, 12:23 AM | #1 | ||
Guys,
I can open my passenger door from the outside but not from the inside. Any ideas what is causing the problem. Cheers |
12-05-2021, 12:30 AM | #2 | ||
Check the cable linkage from the inside that runs down to the latch mechanism. So that requires the door card off, but thats not difficult.
12-05-2021, 12:42 AM | #3 | ||
The metal rod is what goes to the external handle, the cable is what connects to the internal handle, if that helps. So it could be busted plastic bits on either sides, or if its the rear door, check if the child lock is on. Ive only repaired an au ute, so no rear doors.
