27-03-2021, 04:42 PM | #1 | ||
It seems my alternator is knackered on my 2010 tdci 2lt diesel. I've connected the multimeters neg lead to the neg battery terminal and positive lead to the postivie terminal of the alternator and I get a reading of 12.34amps, which is the same when both leads are on the battery terminals. When the engine is running, there is no charge going to the battery. I'm on the verge of trading this unit in so am looking for a standard unit to keep it going. Where would I find a reliable recond unit, or even 2nd hand unit? I've found the video online showing the process, that's not an issue, just the sourcing of a replacement unit.
cheers B. |
27-03-2021, 06:13 PM | #2 | ||
Does your negative terminal have a battery monitoring sensor? If so then your vehicle is fitted with smart regenerative charging, meaning the PCM will only turn on the alternator to charge once the battery state of charge falls below 80%. So if the state of charge is above 80% then the PCM to save fuel turns the alternator off, thus not charging the battery and you will get normal battery voltage. This is normal operation.
28-03-2021, 04:55 AM | #3 | ||
no, this is the 2010 model, it is not fitted with the sensor. If the alternator was not charging, shouldn't the battery warning light come on?
28-03-2021, 10:11 AM | #4 | |||
thanks for your reply re the BMS, never knew of it. cheers B. |
28-03-2021, 10:55 AM | #5 | ||
voltage is low if the alternator is working it should be about 14 volts to charge a battery
28-03-2021, 11:11 AM | #6 | ||
28-03-2021, 12:51 PM | #7 | ||
Hi. More likely the brushes need replacing, they will be at that point where they are just touching the slip ring and pass a little current for the field windings but not enough to produce a full output. The power diodes tend to last for ever and I think I have replaced about 2 exciter diodes in 50 years. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
28-03-2021, 01:05 PM | #8 | |||
28-03-2021, 01:36 PM | #9 | |||
