28-01-2021, 04:42 PM | #1 | ||
Does anyone know how to disconnect the fuel line connectors in the engine bay so I can purge the lines after a fuel filter change?
28-01-2021, 07:59 PM | #3 | ||
So press down on the triangular tank and pull apart; yes?
regards Blue |
28-01-2021, 11:48 PM | #4 | ||
Lift up the triangle part. Put a small screwdriver into the fitting on the opposite side to clear the bottom of the connector from the pipe ridge. Pull the connector off.
