Old 26-12-2020, 06:45 PM   #1
TER2BO
REV8380
TER2BO's Avatar
Default Mk1 Cortina No power to Distributor
Hi I have a 1965 Gt Cortina Group N Race Car. Its been in storage but could not start it prior to that after having new extractors made and fitted.
I am going thru the car step by step but seem to have come to a problem.
As part of these steps I have a new battery, a new gear reduction starter motor.
Orginally had a Ballast Performance Coil and 1.6 omh resistor ,Ignition Delevopments modified Bosh Distributor (no vaccum) and NGK BE 9ES plugs.
I had not been able to get any spark from the Distributor.
I have since replaced the Coil and the Resistor and changed the points to Electronic but still have no power going to the distributor.
I have followed and double checked the wiring diagrams supplied to fit the Starter and Electronic Ign. module but with no success so far.
The only major change to the electrics was the swap of the main starter lead to the positive side of the solenoid and the activation wire to the starter to the other side of the solenoid. But the car may of had this problem after the exhaust fitment. Before that it started.
As the car cannot be moved at the moment any ideas or help would be appreciated.
For Older Racing Drivers
2006 SY Turbo Territory - Dual Fuel, Debunged, F6 Lower Snorkel,Tune, 20"Rims and Pedders Suspension.
Previous Ford Rides
Tickford AU & SVO EA S/wagons - Dual Fuel
Mk1 & M2 Escorts - modified
1969 Mk2 GT Cortina - very orginal.
1964/5 Mk1 GT Cortinas Group N Racing
1965 Mk1 Lotus Cortina Group N Racing
1964/5 Ford Mustang Group N Racing
TER2BO is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2020, 08:07 PM   #2
11ford11
Default Re: Mk1 Cortina No power to Distributor
Is coil still a resistor type with the resistor in series with it.
If so....
Do you have ignition power before feeding thru resistor
Have you fed ignition power to ignition module from point before feeding power thru ballast resistor assuming module requires 12volts to operate
Pulse wire from ignition module to negative side of coil
Wires from starter push on connections should be one to operate cranking and the other feeds to the coil side of ballast to bypass ballast when cranking
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2020, 08:42 PM   #3
TER2BO
REV8380
TER2BO's Avatar
11Ford11,
Thanks for the quick response. Yes the old and new coils are ones that require a Ballast resistor.
I have power on both sides of the resistor.
The pulse (black) wire is connected to the Neg. side of the coil.
I will check again to make sure the other wires are in place as you mention.
Just adding to what I already posted I am not getting any power out of the Main Coil to distributor lead. Hence no spark.
Previous Ford Rides
Old 27-12-2020, 10:36 AM   #4
11ford11
Disconnect coil wires and put a test light (not a led one) make by soldering a couple of wires to a flasher globe and check for pulse when cranking
If you have pulse check for faulty coil - coil lead - missing carbon brush or rotor down to earth
If no pulse check for faulty wiring - module or distributor pick up
Verify you are not loosing power to coil when cranking
Old 27-12-2020, 12:08 PM   #5
Tassie f100
Just run a lead from the battery to the coil then try to start it.Won’t do any harm running for a couple of minutes without a resistor
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
