Old 25-10-2020, 01:37 AM   #1
inventiv
inventiv's Avatar
Default Epic Focus Guide - changing thermostat, water pump, thermostat housing, all hoses, flushing the system
Hey everyone, happy weekend! If you’re planning on doing any work on your Focus LR cooling system – replacing a leaking hose, bad water pump, leaking thermostat housing, bad thermostat, or just want to flush out and replace your coolant/antifreeze, check out this video. I detail a complete cooling system overhaul on A Mk1 Focus, covering everything except a radiator swap (mine is good). I hope you like it! Cheers
https://youtu.be/ktZY29VX390
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2020, 11:15 AM   #2
brucewarring
Default Re: Epic Focus Guide - changing thermostat, water pump, thermostat housing, all hoses, flushing the syste
Loved the silicone hoses tried to find some for my LS but no where to be found?
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2020, 10:36 AM   #3
inventiv
inventiv's Avatar
I had to get them from the UK mate. Try eBay UK or Burton Power is where I got them from. Hope that helps...
