Old 15-10-2020, 12:22 PM   #1
murjak10
Default ignition barrel
morning folks, i'm new to the forum, had problems with ba ignition barrel, following good youtube vid I have removed and repaired the left side of the barrel, four times as i found a spring left over first time and no good response subsequent attempts, dont want to remove barrel again as lugs on aluminium cup are breaking, end result is that key seems to be operating well but no power at all, any suggestions welcomed, jak
murjak10 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2020, 06:37 PM   #2
tweeked
N/A all the way
tweeked's Avatar
Default Re: ignition barrel
If you want to try yourself again - there is this kit
https://www.ebay.com.au/itm/FRK-1-Fo...EAAOSwnCpewPN2
I had it fitted though as it is pretty fiddly, done in Ringwood but if you call or text 0417439719 this guy will probably be able to point to a installer - $450 fitted with a lifetime guarantee. Took the pro half an hr to do and it feels brand new.
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2020, 07:01 PM   #3
11ford11
Check ignition fuse in under bonnet fuse box
Or switch contacts aren’t moving/working
Turn ignition on and check for power at red/green wire with ignition on
11ford11 is offline   Reply With Quote Multi-Quote with this Post
