05-06-2020, 09:22 PM | #1 | ||
I am trying to find stainless tube connectors L & T pieces similar to poly irrigation connectors.
I want them to fit 25mm OD stainless pipe and hopefully something I could drill small holes into the pipe and hold together with grub screws. am I dreaming?
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
05-06-2020, 11:05 PM | #2 | ||
this is what I am after...
Shudder at what price I am looking at but from Brisbane...
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent Last edited by Tonz; 14-06-2020 at 03:03 PM. |
06-06-2020, 12:13 AM | #3 | ||
Would these do: https://www.aliexpress.com/item/32797368058.html If so try 3D printer parts places or https://www.ebay.com.au/itm/Stainles...frcectupt=true
regards Blue |
06-06-2020, 12:26 AM | #4 | ||
Also called "Double Tube Linear Rail Shaft Clamp Connectors" e.g https://www.rophenb.com/index.php?ma...oducts_id=2599 I have seen them somewhere in a 3D printing context.
regards Blue |
06-06-2020, 12:30 AM | #5 | ||
They have them here but not likely cheap: https://www.oceaniaic.com.au/product...mp-connectors/
regards Blue |
06-06-2020, 12:32 AM | #6 | ||
regards Blue |
06-06-2020, 12:44 AM | #7 | ||
Radio spares have various round tube cross clamps but none in stainless: https://au.rs-online.com/web/c/enclo...led%22:true%7D
regards Blue |
06-06-2020, 12:50 AM | #8 | ||
There also these: https://zcg.com.au/d/UAM90L-SS316/ and https://zcg.com.au/p/accessories-bra...e/?this_page=1 etc Stainless is available but probably not what you were after. BTW; what size (edit OK 25mm) do you require and for what purpose?
regards Blue Last edited by aussiblue; 06-06-2020 at 12:58 AM. |
06-06-2020, 09:24 AM | #9 | ||
Cabover nut
Tonz, boating warehouses sell 25mm up nylon pole holders and bimini mounts which are very similar to what you are after too. Not to expensive.
I use Whitworth's. https://www.whitworths.com.au/ you can download their latest PDF catalogue.
06-06-2020, 10:20 AM | #10 | ||
I am involved with a camp that has been let run down over years.
One project is the commercial kitchen, while its in good overall condition, there is a lot of wasted space. There are 4 movable trolleys, for food prep or whatever but waste space underneath. Thoughts were to make some type of vertical racking(?) and store serving trays, baking trays etc hopefully the pic shows roughly what I was thinking. As the frame is stainless it would be good to make changes the same. we would need 6 rows long x 4 bars high. that requires a lot of knuckles. Another option is welding stainless mesh another is the bottom drawing, something like a glass shelf support, slide the mesh into it add food grade silicone
