Old 03-06-2020, 02:26 PM   #1
AussieG62013
AussieG62013's Avatar
Default Mondeo Titanium 2015 Petrol
I am picking up a low k's 2015 Ford Mondeo Titanium Hatch with the petrol engine what shout I do when I get and to check etc
FORD FG MKII G6 2013
FORD Mondeo Titanium MD Hatch 2015
K&N Air Filter
AussieG62013 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2020, 05:10 PM   #2
X-AHH
The good, bad and fugly
X-AHH's Avatar
Default Re: Mondeo Titanium 2015 Petrol
If it's dark blue, make sure it's not the one my missus wrote off a few months ago
Time was on my side!
X-AHH is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2020, 05:20 PM   #3
AussieG62013
Originally Posted by GasoLane
Or send him a PM, he was online yesterday.
No it's pearl white love pearl white.
K&N Air Filter
Old 04-06-2020, 09:57 AM   #4
asteele-xr6
I did 85,000km in mine, and it was rock solid.
Check the tyres very carefully - uneven wear could mean that even though the outside edge of the tyre looks good, the inside could be stuffed. Replacement tyres can be $400+ each, so you don't want to be replacing any if you can help it. I was regularly getting the alignment done, and even then didn't get full use out of my sets of tyres before they had to be replaced.
If buying from a dealer, ask them to apply the latest SYNC3 software update, and also ask for a map update too. Don't let them fob you off that the SYCN3 updates are done over wifi, they have a USB they insert which works and is quick too.
You would want to check the aircon is working and cold across all vents - if some vents are not cold, then there is a leak. I had no issues with mine.
Find out when the battery was last replaced - you will most likely need to replace it again at the 3yr mark.
Check that glass roof for any cracks or damage - I was told that the replacement is hideously expensive. I always worried what would happen on an unsealed road or hitting a pothole accidentally, but never had an issue.
The only other item I can think of is to suggest you start thinking about what you will plug into the 240v mains outlet you are going to get in the back! Very cool, but I don't think I ever got to use it!
Rock solid car, great balance of performance and all the latest features - but you are also (hopefully) getting very cheap running costs too.
Enjoy!
asteele-xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2020, 12:53 PM   #5
AussieG62013
I think the 2015 has the SYNC2 in it and I am already thinking of getting the upgrade kit from MR.FPV so it can have Apple Car Play.
K&N Air Filter
Old 05-06-2020, 08:13 PM   #6
AussieG62013
Holy crap this car is awesome to drive so damm quite and quick.
K&N Air Filter
Old 05-06-2020, 09:15 PM   #7
thebigd
Great to hear the positive feedback on the petrol spec. I've got the (tuned) diesel, and would offer similar comments.
Have to ask, as I converted from an FG2 too...
How does the Mondeo stack up against the Falcon ?
thebigd is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2020, 09:27 PM   #8
AussieG62013
What can I say there worlds apart but I like both.
K&N Air Filter
Old 08-06-2020, 05:39 PM   #9
DougalXR6
I have traveled 48,000 Kms in my 2015 MD Trend Ecoboost which would be the most reliable car I have owned to date.
The only fault it has had is a leak from the seal around the windscreen washer pump. The windscreen washer bottle and pump were replaced under warranty as the car was under three years old at the time.
The car is still a pleasure to look at and drive. I was planning on purchasing the updated Mondeo Titanium this year however, Ford AU ruined those plans.
I purchased a VW Arteon instead, which is the first VW I have ever owned and am hoping it proves to be as reliable as the Mondeo.
DougalXR6 is offline   Reply With Quote Multi-Quote with this Post
