Old 23-12-2019, 04:37 PM   #1
zeppelin_1988
Default 2008 LT Focus Vibration
Hi All,
I have a 2008 LT Focus manual with 130k, at about 40kph a vibration is noticeable through the car. It varies with road speed but not RPM so i'm pretty sure it's not the standard engine mount issue. Also the noise associated seems to be coming from the rear. What else could it be? Drive shafts? Rear wheel bearings? Any help would be muchly appreciated.
All the broken things
zeppelin_1988 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2019, 04:59 PM   #2
marg99
Default Re: 2008 LT Focus Vibration
you sure its not wheel balance issues
Old 23-12-2019, 05:23 PM   #3
zeppelin_1988
Pretty sure, had new tyres 10k ago with different wheels as well. Issue was/is still present. Has progressively gotten worse.
Old 23-12-2019, 06:23 PM   #4
marg99
check that the front bearing hubs are not failing by seeing if the front wheel have play when jacked up You can do the same with the rear wheel bearings Push top and bottom of the wheel.
Old 23-12-2019, 06:49 PM   #5
leakey
leakey's Avatar
Do you have vibrations at rest? i.e. does mirror wobble? I have vibes at rest and at certain speeds and it turned out to be engine mounts, namely the big bugger on the driver's side.
I changed myself with an Ebay cheapie, but problem came back after only a couple of months. Now have three new OEM mounts and it's great. Been a few years now.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
