Old 25-07-2019, 10:46 AM   #1
08ESE
Default 2010 tdci. air bag and tc lights on
Hi guys
My 2010 tdci has the airbag light on, and the traction light on.
forscan says there is a trouble code for
steering angle sensor ( we just changed the rack )
air bag b0001 open circuit, drivers
left rear abs
also noticed that the horn doesnt work
could it be the clock spring, even though the cruise and menu buttons on the wheel still work?
stumped
08ESE is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2019, 08:52 PM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: 2010 tdci. air bag and tc lights on
Steering angle sensor needs to be reset because of your new rack. If by doing the rack they've disconnected the airbag then that may need resetting as well, doesn't matter on some vehicles even of you've disconnected the battery.
Abs likely to be a wheel speed sensor or pump issue
The horn could be a connection not put back, wouldn't be the first mech to forget connecting it. In any case check the fuse box for blown fuses before opening the horn up.
If forscan can't rest them then it may need dealership tools or equivalent.
Hope it helps
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2019, 06:30 AM   #3
08ESE
Clock spring was stuffed. All good now
Old 03-10-2019, 05:47 PM   #4
cobrin
Challenge Accepted!
cobrin's Avatar
cheers for the follow up
