Old 01-06-2019, 03:04 PM   #1
Charlesj
Post 2011 Mondeo issue
Hi all, first visit in so greetings!
I’m having a problem with a 2011 Mondeo with the DCT 450 gearbox.
I recently changed oil and took off the valve block cover to clean internal filter magnet to do this I unhooked the electronic feed ( battery disconnected up front) the issue is after buttoning it up I went to start car (in park through whole process) but the vehicle didn’t recognize park position. Tried to shift to neutal and it locked in reverse - disconnecting battery allows me to move to neutral but park position is locked out. Only symptom is the dash reports low battery volts. I have a FIXD scannerbut nothing coming back on the codes so looking for some inspiration - car has not moved or started since work
Thanks
Jon C
Charlesj is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2019, 06:17 PM   #2
Charlesj
Default Re: 2011 Mondeo issue
For additional info - ran the onboard diag. No DTC’s present warning of low battery (12v registered. Have charged and confirmed connections no change anyone help??
Old 03-06-2019, 06:28 PM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
Tread moved to where it might get more response.
Old 04-06-2019, 01:15 PM   #4
bundybear75
bundybear75's Avatar
The app usually used on these is Forscan, with a Bluetooth or wireless OBD dongle.
Was there any plugs or cables removed when taking the valve cover off? Sounds like something has gone out of adjustment.
When I change the DCT fluid, I just replace the external cartridge filter. Not sure why you would need to take the valve body cover off?
Have you checked the levels? Car needs to be completely level and the refilling procedure adhered to.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2019, 03:36 PM   #5
rondeo
The only cheap scanner which can show Mondeo TCM data is Forscan.
Next is UCDS I think.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2019, 10:42 PM   #6
Charlesj
I had an intermittent sensor code popping so wanted to clean the internal filter magnet off.. I did disconnect the transmission loom during the process so very possible it’s cleared a memory...
External filter was changed and oil level filled but the next step was running vehicle to top levels off which I can’t do because of this issue..
Anyone got a reset procedure / relearn for the gearbox? I’ll have a look for forscan and see if I can get hold of a unit.. not used scanners much so might need a guide..
Thanks for help in advance..
Old 06-06-2019, 06:16 AM   #7
bundybear75
There is a fairly common issue with the speed sensor in the DCT transmission - unfortunately a fairly expensive fix. Mine occurred at about 135,000km.
Have you double checked the plug? You didn't damage any pins trying to plug it back in? This may be the issue??
Forscan is available as an app for you smartphone. I found it on the play store and it was around $7 from memory. I use a OBDLink MX via bluetooth but if you use an I-phone you would need the wireless version. I also successfully used a cheaper ebay OBD bluetooth dongle when I first had issues
2002 BMW R1150GS
