Old 27-10-2018, 03:35 PM   #1
wasim
Default Removal of airbag from the steering wheel
What is the tool I need to remove the retaining screws to take the airbag off the steering wheel?
Thanks, Wasim
wasim is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2018, 05:18 PM   #2
macman
macman's Avatar
Default Re: Removal of airbag from the steering wheel
You can take a notch out of a suitable size flathead screwdriver.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2018, 06:43 PM   #3
wasim
Great - Thanks
Old 28-10-2018, 12:54 AM   #4
superroo
You can't stop the signal
superroo's Avatar
It's a Torx Plus Security bolt (5 point, centre post). It is odd as torx is usually 6 point.
If you use the screw driver method above, once you get them out you replace with Allen key bolts. The screw driver generally doesn't last.
Or you can buy the specific bit. I know this SP Tools bit set has the correct one
http://www.sptools.com/en/product-li...r-bit-set.html
Old 28-10-2018, 12:33 PM   #5
wasim
Thanks for the tips and advice - I modified an old screw driver and it worked a treat.
Regards, Wasim
Old 02-11-2018, 10:50 PM   #6
NCII40
XR6T BA 2002
NCII40's Avatar
For any future references
https://fordforums.com.au/showpost.p...4&postcount=34
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
