I jumped in the car today an noticed a light on ..I've never seen it before an don't know what it means,it's like a box with a fan in it??
It's on the left side third from the top...in the rows of lights left an right of the Speedo. I don't think it's low on water light ..that's the water spray looking light down the bottom
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B] |
#2 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
low engine coolant level warning light so check the coolant level uk
I topped up the coolant so it's full...I started the car an let it circulate put cap back on an took it for a run....damn things still on...is there a reset button or something
common fault was the coolant sensor at bottom of overflow bottle - pull plug and bridge connection and recheck light....
Will do thanks man...hope that's all it is
Yer walked out today an checked to see if that light was still on ...yep sure was
So I unplugged the lead ..wiped it a bit an plugged back together an BAM...problem was fixed ..no more light..
