Old 19-03-2018, 10:02 AM   #1
LordFordNZ
Default MC Mondeo front discs/rotors
Looking at changing the front discs on MC Mondeo TDCI, and see on ebay there seem to be 2 size stud holes (13.8mm vs 15.8mm). Short of pulling the wheels off to measure them, is there a way to know which ones to go for?. I just the rear discs, and the holes in the discs were bigger than the studs, though the locating screw centred everything up on the hub, so was wondering if in doubt go the bigger hole ?)
LV MKII Focus XR5 - no mods yet!
LordFordNZ is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 10:43 AM   #2
ope126
ope126's Avatar
Default Re: MC Mondeo front discs/rotors
Here is a post I did a few years back, it has part numbers to help you; https://fordforums.com.au/showthread...ght=mondeo+ate
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 01:53 PM   #3
AlanD
I suspect it might be a matter of wheel and lug nut combinations.
With the smaller rotor hole a lug nut may hit the rotor before it has seated onto the taper in the wheel hole properly.
Might be a problem with steel wheels (Do they ever get fitted to a Mondeo imported into OZ?) where the wheel material thickness is not as "meaty" as is usually the case for an alloy wheel.
So a larger hole in the rotor would allow the lug nut to travel further along the stud. This would mean the lug nut has engaged with more thread turns of the lug and seated properly onto the seat in the wheel.
You also need to be careful bout "acorn" type lug nuts, which need to have more tapped depth than the exposed part of the stud when the wheel is seated against the rotor.
Just a thought.
AlanD
Our Drive: Mondeo
MD TDCi Titanium Wagon
Ruby Red
AlanD is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 04:02 PM   #4
rondeo
Front discs have 15.8mm stud holes on my MCs.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2018, 12:55 PM   #5
Faolan
Just a thought.
Makes sense to me . My wheel nuts have an extra flange and look like they don't make itbthe to the rotor at all. I have the zetec factory alloys.
Did LordFordnz get an answer to share?
Faolan is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2018, 06:25 PM   #6
Faolan
13.8mm stud holes on mine.
2010 MC Zetec tdci-. Standard Zetec alloys. My discs have been replaced previously by Ford.
Old 26-05-2018, 09:38 PM   #7
cobrin
Challenge Accepted!
cobrin's Avatar
you'll see in the other thread the same here, I bought these:
https://www.buycarparts.co.uk/ridex/7999282
sourced the pads locally Bendix GCT $75.
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
