Old 15-02-2018, 11:05 AM   #1
LaserLikeFocus
Default Engine Loud, Clutch Working, Car won't go into Gear (2007 CL LS FOCUS)
Think I need a new car.
The problem is the same as stated in this article:
https://www.transmissionrepaircostgu...and-wont-move/
The problem is, my car is the opposite - a FWD manual.
Only noticed engine a little louder yesterday, came home last night, as car bumped (gently) by driveway, notice an audible bang and then the car won't shift....into any gear.
Tried pumping clutch - no avail. No smell, doesn't seem stuck or burnt out.
Car is now noticeable louder on start up (only marginally at idle) then noticeably with increased RPM.
Is it just a loose circlip etc? These cars are very low to the ground on the front end and I don't have a jackstand and blocks or a hoist, so does it need to be towed?
Is it a serious problem or not? No OBD II codes/no engine warning light issues.
LaserLikeFocus is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2018, 11:10 AM   #2
LaserLikeFocus
Default Re: Engine Loud, Clutch Working, Car won't go into Gear (2007 CL LS FOCUS)
I hate crap like this...too many possibilities:
Cylinder issue?
Fastener issue?
Hydraulics issue?
Is the clutch actually worn out and slipping? Why the audible "bang"?
Old 15-02-2018, 11:18 AM   #3
LaserLikeFocus
Just did a little test.
Tried to dump the car into reverse at 3000 RPM...
No stall, car actually rolled forward (driveway slopes down) and then revs dropped slowly and I didn't have the patience to see them go back to idle, seemed stuck at over 1400 RPM, idle is 850-1100 RPM IIRC(?).
The clutch is gone, no?
Old 15-02-2018, 11:22 AM   #4
LaserLikeFocus
Could it still be the selectors?
Old 16-02-2018, 09:43 AM   #5
LaserLikeFocus
Turns out the inner CV boot has torn itself apart and the driveshaft has separated from the transmission at the inner CV knuckle.
Now I am worried about the stall/burnout test I did.
Gonna get it towed to the shop etc.
