Falcon Fanatic
Hi i have a Mk2 Ba xr6 and was wondering if an fg steering wheels would fit it
Boss 335
Yes, done it before . But why would you? BA wheel is far superior and I would be going the other way.
3 users like this post: |
Falcon Fanatic
#4 | ||||
FAWD - No Boundaries
![]() Join Date: Jun 2010
You need an F-Series wheel and clock-spring... and you need to make a jump loom between the F-Series clock-spring & B-Series column-dash loom plugs. You also need to modify the F-Series audio circuit board (in the audio switch pod) so the F-Series audio controls talk to the B-Series stereo. Other than that... the F-Series airbag has the same resistance as the B-Series airbag... the F-Series cruise control switch pod operates the B-Series cruise control... the horn works too... and the F-Series phone switch will operate the B-Series Bluetooth unit too (as long as you have made the jump loom mentioned earlier). However.. having successfully completed an F-Series wheel conversion into a B-Series... it then allowed me to work on upgrading the F-Series wheel to accept Paddle-Shift paddles... ![]() ![]() ...which I've taken from a 2010-2012 Ford Taurus wheel ! At this point in time... I haven't found anything suitable to fit to a B-Series wheel (probably is something suitable out there... I just haven't found it... yet). The Paddle-Shift upgrade is a whole other story... but we have worked out how to interface with the ZF6spd (B & F-Series) at this stage.... and it works really well ! The wheel side of things is sorted... but we're still working our way from "prototype stage" to "finished product" stage with the trans interface ! D
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
Can be done but is FAR from being a bolt-on job.
If you really want to know what involved read this thread from around post #4710; https://fordforums.com.au/showthread...el#post5601215 Pics & thread with thanks to Gothefalcon ;) ![]() ![]()
#6 | |||
Falcon Fanatic
