15-01-2017, 06:59 PM | #1 | ||
Eight month old Mondeo Trend. Rust and blistering on stonechip on the bonnet. It's a lease car so I'm not overly bothered, but if I'd bought this I'd be fuming
16-01-2017, 12:41 AM | #3 | ||
Challenge Accepted!
Nearly 8yr old Mondeo here with more than 20 stone chips on the bonnet, all touched up, none with rust.
16-01-2017, 12:21 PM | #4 | ||
Tippy-tronic Free Zone
The panel is dented. Must have been a big stone.
16-01-2017, 03:53 PM | #6 | ||
Call me dirt... Joe Dirt
I got sunburnt on the weekend coz I didn't apply suncream.
I blame Ford.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
16-01-2017, 06:59 PM | #7 | ||
oh well, I guess my expectations of what is acceptable after eight months on a car that is supposed to have a 10 year anti-perforation warranty is different to others here - never mind.
16-01-2017, 07:15 PM | #8 | ||
Any car that gets a whopper of a stone chip that takes away all the paint and goes back to baremetal will rust in that spot as it's no longer protected. If it gets touched up quick enough it won't be a problem. Without the paint on the metal, it's no longer protected in that spot... pretty basic stuff.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
16-01-2017, 07:26 PM | #9 | ||
On the once or twice I had copped any major chips or scrapes on coloured cars back in the day, I'd straight away rube them down with wax and grease remover, fill the chip with the best match of crayon to the colour I could get, then wax over the top. It was a bit ugly and only a temp fix, but I never had rust issues and the fix was only obvious because of the dent or if you knew it was there. On fridge white work cars I use white out. Ugly again, but it stops the rust. Work only fix cars if they are undriveable, and my bosses definition of that is extreme, one guy has been driving a van for over a year where the top of the drivers door is bent 2 inches out from the car. He gets wet when it rains, apparently that's Mitsubishis version of active fatigue management....
16-01-2017, 08:02 PM | #10 | |||
Sent from somewhere using Tapatalk
16-01-2017, 09:18 PM | #11 | |||
The paint coating has been compromised in this case and the raw metal has been exposed. All stone chips where it has gone down to the metal should be touched up ASAP. Grab two watermelons, poke a hole in one, leave both on shelf and see which one starts to rot first. I kinda thought this was common knowledge.
8 users like this post: |
16-01-2017, 09:42 PM | #12 | |||
bitch lasagne
https://www.ford.com.au/content/dam/...leWarranty.pdf
17-01-2017, 07:34 AM | #13 | |||
It looks like a pretty decent stone chip. Where the paint and anti-corrosion coating have been removed, yes, you will see surface rust if it's not touched up. But there shouldn't be rust spreading from the bare metal under the paint like that. It does make you wonder how well the e-coat was applied. There's been a few posts regarding quality issues on the MD. I might just look for a late model MC when it's time to change the MB.
17-01-2017, 08:06 AM | #14 | ||
It looks like bog on my computer.
2 users like this post: |
17-01-2017, 10:39 AM | #15 | ||
And now because it wasn't acted on immediately by the OP it is now going to be harder to fix
Didnt they come out with touch up pen? Only costs like $20 if it didnt anyway
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
17-01-2017, 11:11 AM | #16 | |||
R51 Pathy, 91 Jayco Swan
17-01-2017, 07:49 PM | #17 | ||
The e-coat (primer / base coat) wasn't applied properly. I haven't seen anything like that since we stopped assembling cars in NZ about 20 years ago.
18-01-2017, 09:30 PM | #18 | ||
My 1974 Dodge ute nearly broke in half with rust, a cop asked me if I had any reason for driving the vehicle with rust in it (which I didn't). After it was stickered I sold it to a wrecker.
It had a catch can for oil and I put the oil back in the engine now and then: call it eco mode. On my MC bonnet chips I used some matching paint which is now a solid lump. The car has had zero mechanical issues in 160000km. Just brakes, once, and buzzing vacuum solenoid which I replaced as a precaution. I like the MC but I wouldn't mind going back. If you live near the sea, the rust might be worse, but the life . . . |
25-01-2017, 02:26 PM | #19 | ||
spoke to the corrosion supervisor at yypg this week and he confirmed that rust like that is not normal. Mondeo hoods are Zn coated. His suggestion is that the Zn coating may have been buffed off in that area for some reason
03-03-2017, 09:02 PM | #20 | ||
okay, so that didn't end up too well, but I'm not sure a dab of clear nail varnish would really have helped much. The paint literally peeled off under pressure wash
03-03-2017, 09:34 PM | #21 | |||
06-03-2017, 07:34 PM | #22 | |||
