Old 29-08-2016, 01:50 PM   #1
Aether
Default Capri Electronic Ignition
Hi guys
Just wanting to get some opinions about electronic ignition for a V6 Capri. I have heard some good things about making this upgrade and just wondering what the benefits are and if anyone has any recommendations for what product to buy?
Is it worth doing during the build or would it be simple enough to do this once its on the road? If its simple enough to add this later then I might use the money ($300?) for other expenses and just concentrate on getting the build finished with the old coil and resistor I still have.
Thoughts greatly appreciated!
My Capri Project: http://fordforums.com.au/showthread.php?t=11423076
Aether is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2016, 08:52 AM   #2
1973rs
Default Re: Capri Electronic Ignition
I converted mine - fitted out the original distributor - has been really good
1973rs is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2016, 11:24 PM   #3
Capriman
formerly ford3000gt
Capriman's Avatar
This has to be the best modification to any V6 Capri. Jerry Soldatas at Ignition Torque in Bayswater, Victoria did mine and it'sthe best money I ever spent on my V6 Capri. A MUST do for reliable motoring.
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 12:01 AM   #4
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Easiest conversion is using the Petronix system. Convert to points in about 15 minutes as long as you have 12V going to dizzy, otherwise you will have to run a new wire....
Info and catalogue below..
http://www.pertronix.com/catalogs/pd...ition_conv.pdf
You can buy from these below or Ebay or contact them direct..
http://www.pertronix.com.au/availfrom.html
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 09:20 PM   #5
allanv6gt
Tippy-tronic Free Zone
Accuspark comments?
Old 05-09-2016, 06:46 PM   #6
gtv6capri
Originally Posted by allanv6gt View Post
Accuspark comments?
Hit and miss. I bought about 9 over from the UK and have had 3 fail. I was thinking it may relate to the resistor.
gtv6capri is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2016, 09:01 PM   #7
39ClevoUte
39ClevoUte's Avatar
You won't beat one of these.
https://wiki.autosportlabs.com/MegaJolt_Lite_Jr.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2016, 09:07 PM   #8
39ClevoUte
39ClevoUte's Avatar
Select Megajolt
https://wiki.autosportlabs.com/Main_Page
https://forum.autosportlabs.com/
https://forum.autosportlabs.com/viewforum.php?f=9
