Old 22-05-2016, 03:48 PM   #1
brooksy1476
Default MC Mondeo Wring Schematic
Hi all
Having dramas with the drivers door not showing as closed, door control module swapped over and proven ok, would any have access to and be able to share the wiring from door back to management system/fuse box?
Thanks in advance.
brooksy1476 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2016, 07:11 PM   #2
rondeo
Default Re: MC Mondeo Wring Schematic
According to Haynes the door module communicates on the MSCAN bus (Vt/Og,Gy/Og pair) to the GEM which is under the glovebox, referred to as the central fuse box in the owners manual. The front driver door lock and rear door module are linked to the front driver door module via LIN bus (one wire: grey/blue).The fuse (FA2)for the front driver door control module is in the rear fuse box, shown as a black wire to terminal A2 on the module.
Apart from Haynes manual which is very limited, I believe you can access wiring diagrams and manuals on etis for a $50 subscription.
I ran out of pic space so can't post pic from Haynes.
Forscan with MSCAN might help, don't know but I think does at least see the door modules.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2016, 06:18 AM   #3
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
There are 12 diagrams in total for this set and they are different based on whether you have the power rear child safety locks or not.
Send me a PM and I can send you the relevant ones.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2016, 09:48 AM   #4
brooksy1476
Thanks Russ and Rondeo for your help, really appreciated
Russ PM sent
