Old 01-12-2015, 01:00 AM   #1
ope126
ope126's Avatar
Default RE: Mondeo Spare Wheel / Space Saver
Hi All,
As I now have a Titanium TDCi and have replaced my Zetec EcoBoost there is one thing that I wish I could have back, additional load space (height)...
The Titanium uses a "Full Size" temporary wheel, where the Zetec had a "Space Saver".
As such, the increase height (10cm) impacts on the potential of placing larger suitcase in (which I do quite a lot).
I am not doing any long distance travel, as such I am not concerned about the space saver as a spare.
A couple of guys have done the opposite and replaced the space saver with a full size spare; http://www.fordforums.com.au/showthr...er+spare+wheel and here; http://www.fordforums.com.au/showthr...eo+spare+wheel
Can anyone with a non Titanium model confirm that the boot mat / carpet just sits on the body frame and on top of the space saver wheel. Or does it still have a foam inlay that is sits on? I just can't remember!
The Titanium has a two piece foam inlay that increases the height and the boot mat sits on top of it and the full size wheel.
The full size spare in my car is a Michelin Primacy HP.
I have been looking at space savers and they all seem to be Maxxis or Hankook. Is that the norm?
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 05:56 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Mondeo Spare Wheel / Space Saver
I can answer the latter question in as much as the factory space savers were typically equipped with Maxxis tyres although the Falcon based ones were mostly Goodyear even when the rest were Dunlop!
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 07:29 PM   #3
cyclone1410
Originally Posted by ope126 View Post
Hi All,
I have a Zetec Ecoboost and the mat sits on the frame without the foam inlay.
Latest ride: Ford Falcon FG X G6E
Fondly remembered: 2013 Ford Mondeo Zetec Ecoboost Hatch
cyclone1410 is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 10:42 PM   #4
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
The catalogue lists different carpet for mini spare wheel or full size spare steel wheel, so I guess there must be some sort of difference that is on top of colour and if sedan, 4 door wagon or 5 door hatch and year of manufacture. All up there is about 5 different combinations of boot carpet for MA to MC Mondeo!1
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2015, 12:03 AM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
I have a Zetec with space saver the carpet has that 2mm?!? melamine panels for strength. It sits on the steel raw bodywork/bed and space saver itself.
I went to get the fuel funnel recently and had to remove the tyre to get access to the foam tool holder. That sucked cause I thought it was upside down and sitting in the wheel.
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2015, 10:12 PM   #6
ope126
ope126's Avatar
I have just discovered this!
I purchased a brand new Continental Space Saver (from a 2014 Mondeo), however once installed I realised two things;
1) The screw down handle is now too high, so will need to find the correct part number at Ford so the carpet will fit flush.
2) The carpet is (as mentioned) now incorrect and does not sit rights. I think if I recall my Zetec had a foam strip running under the front edge of the carpet as it meets the seat back. My seat back is now exposed as the carpet does not fit flush.
Also, I now need to find somewhere to place the Antenna that sits in a groove / slot in the Titanium foam. As without this foam, I will now need to find another location for it...
Old 05-12-2015, 12:39 AM   #7
GTLEGEND
Sedan or Hatch correct part number for mini spare wheel screw down handle is 7G92 1448 AB or for a wagon with mini spare it is 7G92 1448 BB. The screw down for a full size steel wheel which is what you have is 7G92 1448 DB...
I can advise correct part number for carpet if you tell me all details about your car..
Old 05-12-2015, 12:46 AM   #8
ope126
ope126's Avatar
Yeah, the supplier of the Space Saver Tyre also gave me the screw down handle; 7G92-1448-BB. Which now seems to be that it was supplied from a LX Mondeo Wagon. Hence why this Screw Down Handle is too high and mine (7G92-1448-DB) is too high also!
Old 05-12-2015, 01:28 AM   #9
ope126
ope126's Avatar
PM Sent!
Old 06-12-2015, 07:22 AM   #10
NZ XR6
I'm very pleased to have a full size spare and it doesn't raise the floor that much. But my wagon has 16" wheels, so maybe the Titanium wheel is deeper.
All NZ new MA - MC Mondeos have a full size spare.
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels.
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2015, 07:10 PM   #11
ope126
ope126's Avatar
Ok, so I now have the correct screw down handle; Part No. 7G92-1448-AB for Space Saver wheels.
I also have the foam piece that runs along the back of the seat backs; Part No. 7S71-A11168-AE which now also holds the Antenna and the wire loom.
I just need to source the carpet for the hatch area;
Part No. 7S71-A13065AH-3ZHE. I have been to a couple of wreckers however they all look to "USED" and the glue is separating from both side of the centre panel. The search continues!!!
Old 11-07-2016, 07:24 PM   #12
ope126
ope126's Avatar
I no longer need the Space Saver spare wheel / tie down / or the foam trim piece to suit. Happy to sell for $80 (pick up or plus delivery) to someone on the forum. Drop me a PM, if not I will chuck on eBay later in the week!
