XR6T BA 2002
Anyone Using this ATM,
Discuss the difference and benefits of water wetter over Glycol coolants Cheers
XR6T 2002 BA
XR6T BA 2002
Thanks mate Will it allow my engine to reach operating Temp though?? Runs at around 90 degrees atm
XR6T 2002 BA
Going with the X-Flow
I think your engine will still run at 90 with water wetter.
90C=195F=thermostat opening temp. If anything, the temp would just be a little less likely to climb under hard use. I noticed that the grade of motor oil I used had a greater influence on operating temp than water wetter. i.e. Engine ran noticeably cooler with 5w-30 as opposed to 10w-40. For everyday use, I think water wetter's greatest benefit is that it allows you to run a coolant mix (giving corrosion and anti-freeze protection), while coming close to the cooling efficiency of 100% water. Since it lowers surface tension, it will find leaks in a tired cooling system. I would be reluctant to use it without coolant unless racing. See here |
