Old 16-11-2015, 12:15 PM   #1
Swedishmoose
Default Engine starts and stops again immediately
Hi there...
Our 4.0 Litre has a new habit.
Starting the engine after the weekend the first time in the morning, engine starts and stops immediately.
Second go everything perfect. Starts quickly and idles smoothly.
I can't think what it could be.
If it was the fuel pump, the engine wouldn't start at all or run smoothly and if there was a vacuum leak, it would also cause trouble.
I haven't checked the throttle body or IAC valve for build up but does anyone else have an idea what it could be?
Thanks for any info...
The Moose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2015, 01:36 PM   #2
FNQracing
RAGE Engineering
FNQracing's Avatar
Default Re: Engine starts and stops again immediately
Try letting the fuel system prime for longer than usual before actually attempting a start? Sounds fuel (pressure?) related to me with the info provided.
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2015, 10:34 PM   #3
superroo
You can't stop the signal
superroo's Avatar
I found it was related to fuel types. Mine only did it on BP ultimate.
Try a change for a month
Old 17-11-2015, 09:19 AM   #4
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Get a ecu scan, that will tell you what the problem is without guessing. Fuel filter ok?
cheer's, Maka
Old 20-11-2015, 05:46 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah I always pause when i turn the key to 'on' and wait until i hear the fuel pump finish priming before I actually start it.
Two other things to try are this: new battery. I had an old battery one time, and the oomph from it was enough to kick the engine over, but not enough to let it catch and continue.
So in that instance before I replaced the battery I just held the key down longer and let it crank away until I was passed the danger zone.
Old 20-11-2015, 10:35 PM   #6
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Wink Re: Engine starts and stops again immediately
I second the battery, had similar issue and new battery fixed it.Quite suprising how much quicker the new battery kicks it over.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
