Old 19-09-2015, 02:39 PM   #1
Cammyron
Default Loose front wheel
Hi guys,
Have noticed a rattle under low speed (around 35km/hr) over the last week. Grabbed the front left wheel and gave it a shake. There is a small (mm or two) amount of play. I am guessing loose hub nut or bearing. Is there anything else it may be?
I can tighten a wheel hub without much issue but replacing bearings is beyond my tool kit.
The car is a 2010 titanium diesel that has done 85,000km
Cammyron is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2015, 06:53 PM   #2
barrys123
barrys123's Avatar
Default Re: Loose front wheel
Not a big job to replace wheel bearing only basic tools needed a socket and ring spanner set and a pair of plyers plus some wheel bearing grease, just undo the calliper bolt and lift up out of the way and remove the hub nut and the disc will come off and tap the bearings out.
just pack the new bearings with the grease and tap them in and put it back together.
barrys123 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2015, 07:07 PM   #3
Cammyron
Ah ok. Had a quick google and people were using weird 3 arm things to remove the bearings that kind of scared me off.
Old 19-09-2015, 08:12 PM   #4
barrys123
barrys123's Avatar
That's only to remove the whole hub assembly
Old 19-09-2015, 09:43 PM   #5
jpblue1000
jpblue1000's Avatar
Surely the bearing needs to be pushed out with more force than a hammer! and reset with a press?
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2015, 11:01 PM   #6
barrys123
barrys123's Avatar
http://www.fordforums.com.au/showthr...+wheel+bearing
Old 20-09-2015, 09:58 AM   #7
Cammyron
Thanks but thas for a b series falcon. The mondeo front is quite a bit different i think. It needs a 32mm socket as well from what i have seen
Old 20-09-2015, 10:21 AM   #8
Cammyron
I should add that there is no grinding/bearing shreading sounds. Just a light knock occasionally and the wheel is very slightly loose. I am leaning towards the hub nut being loose.
