Old 17-09-2015, 10:34 AM   #1
neil3087
Default Oil Consumption
My wife's Focus Trend (2lt engine) is 2013 September build and has 24000 km on it. During the last 9000 km it has consumed 3.0 lt of oil.
When the car was in the drive shaft recall, the dealer stated that an oil consumption problem was common in this model.
From the next service onwards the dealer will be monitoring the oil consumption.
Is anyone else having this problem?
neil3087 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2015, 10:41 AM   #2
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Default Re: Oil Consumption
Did the oil consumption start after an oil change?
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2015, 10:55 AM   #3
neil3087
I've only noticed the oil consumption in the past 6 months which is after the 12 months service.
Old 17-09-2015, 10:58 AM   #4
vztrt
vztrt's Avatar
I'm just thinking the dealer put the wrong oil in.
3L is new engine time.
Daniel
Old 17-09-2015, 10:59 AM   #5
RedChris
My 2012 Trend is on 22,000 km. No oil consumption of any significance.
RedChris is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2015, 11:06 AM   #6
neil3087
The dealer did indicate the engine would use oil if the wrong grade was used.
Old 17-09-2015, 12:00 PM   #7
vztrt
vztrt's Avatar
Who did the service?
Daniel
Old 17-09-2015, 01:16 PM   #8
neil3087
The dealer the car was purchased.
Old 17-09-2015, 11:10 PM   #9
In Focus
Nothing noticeable has been used in the Mrs car. The 1.4 TSI in my Skoda used to use about that amount (since had a fix), but that engine is renowned for having an oil drinking problem.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
In Focus is online now   Reply With Quote Multi-Quote with this Post
Old 22-09-2015, 12:10 PM   #10
mik
mik's Avatar
wow , thats a fair wack of oil, does it blow any smoke or leak any oil ?
Old 22-09-2015, 01:33 PM   #11
neil3087
There are no oil leaks nor does it blow any smoke hot or cold.
A seal was replaced in June 2014 after oil leaked onto the clutch. When the car was in for the drive-shaft recall a couple of months back, it was found the clutch was out tolerance. As the auto trans still shutters, and it appears to be 6 month wait for a replacement clutch.
Old 22-09-2015, 05:50 PM   #12
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Sounds like engine oil leak from rear onto clutch. Note powershift trans as such a good seal any oil leaks are usually kept in the housing until it is split from engine. Oil consumption could be really a leak also this will cause a clutch sudder. I gather the seals that were replaced were input shaft seals? There is no supply issues for clutches more so the ability for a dealer to get it done..
Which dealer...
GTLEGEND is online now   Reply With Quote Multi-Quote with this Post
Old 22-09-2015, 07:01 PM   #13
neil3087
Hi GTLEGEND,
I sent you a PM.
Regards,
Neil.
