Old 09-07-2015, 11:59 AM   #1
XF_Pilot
Default Shift light wiring AU XR8
Hi,
I want to install a shift light only for track days in my AU XR8. I can't find a y threads on it. Can someone give me a run down on where to get the coil pickup for etc.
XF_Pilot is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2015, 02:04 PM   #2
NFV
Default Re: Shift light wiring AU XR8
Best place to pickup the Tach is the ECU or Cluster - there is a CTO (Clean Tach Output) Output (Pin 45 on the EEC) which goes to the cluster. Im not sure what wire it is at the cluster but you should be able to find it easy enough. This signal is a clean tach pulse that doesnt require conditioning for use
NFV is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2015, 10:31 PM   #3
XF_Pilot
That's great. Thanks.
