AU II XR8
Hi there.
Can someone explain to me what's needed to change over to PBR 322mm brakes? Does the calliper bolt straight into the existing spot, or a is an extra bracket needed? Also are the BF and FG the same? The reason I ask, is I'm looking at a set if 322mm of eBay. Description says it includes callipers, rotors and pads. Is there anything missing to suit an AU? Thanks.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
FG G6ET
I brought the above took it to my mechanic and he fitted it no worries to my AU III
2009 FG G6E Turbo |
AU II XR8
Excellent. Thanks for the help!
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Sure do
![]() UK
FG XR50 TURBO
![]() Join Date: Apr 2009
I fitted BA GT premium brakes on my old AU3 fairmont years ago
along with Territiory 328m rear brakes. only thing i had to get washers to line up the rotor centre with the caliper if you don't the rotors rubs ![]() ![]() ![]() ![]() ![]() |
I like the look of the rears
UK
