Old 29-03-2015, 11:20 AM   #1
irwazza
Wazza, FTF Vice President
irwazza's Avatar
Default Timing LV Ford Focus
Does anyone know how to adjust the timing on LV Focus, mine is pinging on acceleration
irwazza is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2015, 11:45 AM   #2
marg99
Default Re: Timing LV Ford Focus
did not think you could do much as its computer adjusted. sure its not the anti knock sensor giving up or poor fuel?
Old 29-03-2015, 06:14 PM   #3
DZFord
DZFord's Avatar
You can advance or retard the timing but moving the crank sensor. Yes the link is to a mazda 3 forum, but we have the same engine: http://www.mazda3forums.com/showthread.php?t=237337
http://www.mazdas247.com/forum/showt...ng-advance-mod
Old 29-03-2015, 10:11 PM   #4
In Focus
Using 91 fuel? 95 or 98 will fix it, but obviously cost more to fill up.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
In Focus is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2015, 07:27 PM   #5
DeKa
That's it. As per the manual, engine noise will increase, and performance will decrease using 91 fuel. That's one way of describing pinging.
DeKa is offline   Reply With Quote Multi-Quote with this Post
