Old 21-03-2015, 10:18 AM   #1
REDDYZ
REDDYZ's Avatar
Default Brake loaders?
Hi all,
My sister's 2012 Focus (Ambiente) has gone for servicing today and the dealer called back saying front pads are almost worn and needs replacement. Cost to replace pads and loaders is $650.
I know what a pad is, disc, caliper, piston and other bits and pieces. Wondering what a brake loader is? And why is it so expensive to replace just front brake pads and "loaders" whatever they are..
Does anyone know what a brake "loader" is on 2012 Ford Focus?
cheers
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2015, 11:39 AM   #2
marg99
Default Re: Brake loaders?
sure he did not say Rotors?
They usually need replacement quickly as the factory ones are soft metal giving betters stopping but wear quick.
Old 21-03-2015, 11:48 AM   #3
REDDYZ
REDDYZ's Avatar
Lol yes marg99 you are right. He was referring to rotors. Anyways, car has done around 28000kms. It seems front rotors are undersized already. Is this normal life span of the rotors on Focus?
Old 21-03-2015, 12:30 PM   #4
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
If you drive suburbia type traffic than probably, I've got an LV and I'm still on original rotors and pads with 85,000km on the clock but I'm 90% highway.
Old 21-03-2015, 12:36 PM   #5
REDDYZ
REDDYZ's Avatar
True. If they are worn they are worn. There isn't anything much that could go wrong with rotors so that they wear off quick. Thanks for your comments.
Old 21-03-2015, 12:55 PM   #6
DZFord
DZFord's Avatar
You could just always ask them for the measurements on the rotors. New is 25mm, minimum is 23mm.
Old 21-03-2015, 05:36 PM   #7
REDDYZ
REDDYZ's Avatar
Thanks for the information. This wasn't mentioned in the report. Will ask for current measurements.
Old 21-03-2015, 06:02 PM   #8
05_ENFORCER
05_ENFORCER's Avatar
Screw Ford and DIY.
Buy some quality DBA rotors and performance pads, last longer and stop better
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2015, 06:09 PM   #9
REDDYZ
REDDYZ's Avatar
Originally Posted by 05_ENFORCER View Post
Screw Ford and DIY.
Agree, eventually thats what I would recommend to my sister to buy parts separately and get it done else where. Its not rocket science to change brake pads and discs. I can do it by myself in an hour for both fronts. But can't help my sister as I'm in QLD and she is in VIC.
Am still curious to know whether the discs are really under sized.
Thanks for recommending DBA. Any suggestion where I can buy them cheap?
Old 21-03-2015, 06:24 PM   #10
05_ENFORCER
PM FLOORED on this forum, Matt is his name, Race Brakes Sydney is the place, great guy, great service, many forum members will agree
www.racebrakessydney.com.au, Phone 02 9609 1101
Old 21-03-2015, 06:26 PM   #11
REDDYZ
REDDYZ's Avatar
Great. Thanks for help.
Old 21-03-2015, 06:28 PM   #12
05_ENFORCER
No probs, anytime
I'll be asking the same question in a couple of weeks for the XR5
