Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 17-02-2015, 06:08 PM   #1
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default FG BLACK Brembo Brake Kits
The FG Black Brembo 4 and 6 piston brake kits use genuine calipers,genuine disc rotors,brackets,pads and in sedans use the factory rubber lines unless you require braided at an extra cost. DBA rotors can be factored into the kits and also a range of brake pads but prices will vary.
These are FF prices and are current
FG Black brake kits
FRONT - FG 355mm Black front 6 piston kits are $3195
FRONT - FG 355mm Black front 4 piston kits are $2350
REAR - FG 330mm Black Rear 4 piston kits are $2250
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 27-04-2015, 08:13 PM   #2
AGS302
AGS302's Avatar
Default Re: FG BLACK Brembo Brake Kits
Are there any front 4 piston kits left?
2009 FPV GS 302 #250/250
ZF And Leather
*Herrod Airbox *X-Force 2.5" Cat Back
Custom tuned by Ben at Auspeed Tuning Mackay to 270.5rwkw.
AGS302 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2015, 01:52 PM   #3
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes we can get them still just let me know by PM if you want to follow up on this.
MATTHEW PEARCE
Phone 02 9609 1101
Old 10-08-2015, 07:44 PM   #4
cosworthfreak
cosworthfreak's Avatar
Hi Matt,
Are the above prices still current?
Also, do you recommend upgrading ute (FPV GS) rear brakes to PBRs when fitting 6 pot fronts, or will the standard rear brakes be fine?
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2015, 10:06 AM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by cosworthfreak View Post
Hi Matt,
Jamie
Yes we can still do the Blacks for those prices and yes i would recommend going up to the 328mm rear set up. We can only get red rears so you will have to paint them but a rear kit can be put together with various options on pads and rotors for under a $1000
MATTHEW PEARCE
Phone 02 9609 1101
