Old 22-06-2014, 03:26 PM   #1
SJG351
Default Drivers Door Handle
Hi Guys, My daughter has broken her exterior door handle (2007 Zetec Hatch) and i was wondering how you access them? I don't want to break anything yanking on the wrong part Cheers!
Steve.
SJG351 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2014, 04:35 PM   #2
marg99
Default Re: Drivers Door Handle
I suspect you need to get at it from inside the door usually a couple of nuts holding it to the inside door skin. what I cannot recall is oif you have to remove the "plate" covering the electric window mechanism. It covers most of the inside door panel under the exterior plastic trim
Old 22-06-2014, 05:00 PM   #3
80rs
when you open the door there is a black bung level with the handle. pop that out and theres a torx screw. undo the screw and the outer handle comes off
80rs is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2014, 11:10 AM   #4
SJG351
Guys, Do i need to remove the door trim and if so how?
Steve.
Old 23-06-2014, 11:15 AM   #5
80rs
No door trim stays on I will attach a pic later if needed but just look for oval shaped black bung inside door level with handle juat above the latch
Old 23-06-2014, 11:26 AM   #6
SJG351
Cheers, I just had her look for it and its there Love this forum guys!
