07-04-2014, 08:23 PM | #1 | ||
BS 60 RV
Hi there,
I've just bought a 1996 el wagon with a few issues, paid $700 bucks for it I would like to know if this is a el or ef wagon for starters as my dad had a ef wagon same year model first issue is that the rear doors don't open from outside and the drivers rear has child lock on as well is there a way from inside the cabin to open it it has duel fuel but when trying to put gas in it or does not want to fill up unknown if its the connection or the pump connection if there any other things I should be looking for all the help is welcomed very much
If life is passing you by,it maybe due to buying that holden that your misses said not to buy |
10-04-2014, 03:33 AM | #2 | ||
To find out if it is an Ef or El wagon,just read what it says on the vin plates.Also,Ef will have a coil pack where as an El will have a distributor.
11-04-2014, 08:09 AM | #3 | ||
The one and only
As said, popping the bonnet will confirm what it is.
Also there will be a few smaller differences around the car, but compliance plate is the most accurate. Seems like you have a bit a work ahead of you.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
11-04-2014, 11:25 PM | #4 | ||
BS 60 RV
Yep Definetly had a fair bit to do
Cheers guys for help
12-04-2014, 01:51 AM | #5 | ||
Is it an Ef or El?
15-04-2014, 08:31 AM | #6 | ||
with the back door, you can undo the hinges and carefully open it by moving it till it lifts, i had to do this with an xf
2000 AU Wagon |
31-05-2014, 02:29 PM | #7 | ||
any results for this?
2000 AU Wagon |
