17-02-2014, 09:30 PM | #1 | ||
my 2007 2 litre manual focus engine warning light come on while going 110km pulled over had the car towed home the book says this is emissions related problem can anyone give me a clue as to what it might be and if it would be safe to drive to my mechanic 40km away any help would be grateful.
18-02-2014, 07:26 AM | #2 | ||
I had a 2006 Ford Focus and the only time the engine light came on was due to a faulty O2 sensor. I suspect (could be wrong though) that you'd need to take it to a ford dealer to plug it into their diagnostic tool to determine the fault code. Maybe your local mechanic will have a diagnostic tool that can identify the code and what the code relates to.
18-02-2014, 07:29 AM | #3 | ||
Sorry, forgot to add that it should be OK to drive that distance to your mechanic, but don't leave it too long, best to get it sorted soon.
18-02-2014, 09:54 AM | #4 | ||
Sorry guys new here don't really know how to post
I have a 2008 territory just bought It was serviced regularly I noticed the engine temp changes in temp a little Not a massive difference doesn't over heat Shouldn't cars normally sit on the same temp most of the tume |
18-02-2014, 12:21 PM | #5 | ||
Yes. Unless a really hot day with Aircon turned on when they will rise a bit. If they rise any more you need to have the cooling system checked out
18-02-2014, 10:44 PM | #6 | ||
thanks for your info guys will take it to mechanic and see what he says will let you know any other info would be helpful.
