Old 04-01-2014, 10:03 AM   #1
Rs31markie
Default Lt focus missfire first thing!
Hi, could someone tell me if this is a fault that's happened to anyone else. 07 focus zetec, 2.0 dura eng, 65k full ford service history, when started from cold it sometimes has a miss fire, it only lasts for 30secs. I was going to change the plugs as a matter of course, but thought I'd put it up on here to see if it's a common problem. The car runs fine when warm. Thanks.
Rs31markie is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2014, 01:48 PM   #2
DZFord
DZFord's Avatar
Default Re: Lt focus missfire first thing!
Yeah this is a fairly common issue, lots of mentions of the same problem on here.
Only usually occurs on cold-starts as you mentioned and also only usually short-lasting.
Old 04-01-2014, 10:08 PM   #3
Rs31markie
Thanks for reply DZFord, is there a fix or is it just something they do?
Old 05-01-2014, 10:55 AM   #4
DZFord
DZFord's Avatar
Often, you just need to let them idle for a few seconds before driving off. Replacing spark plugs helped mine and it seems to rarely ever do it these days (NGK Iridium plugs_
Old 14-01-2014, 10:11 PM   #5
Rs31markie
Thanks DZFord, I've changed the plugs, and it's not done it since, even tho plugs had only done 20k. Thanks again for you're input.
Old 16-01-2014, 09:36 AM   #6
DZFord
DZFord's Avatar
Good to hear it helped!
