29-09-2013, 06:43 PM | #1 | ||
Hey Hey,
I have an AU1 xls ute and when i lock the car with the remote it locks but the lights dont flash. Is this something that i can turn on ? Cheers Des.
AU XLS. |
30-09-2013, 07:42 AM | #2 | ||
Flairs - Truckers Delight
Check your fuses maybe??
30-09-2013, 10:45 AM | #3 | ||
5.6L x 2 pilot
Hi Des.
I assume the you have checked and the hazards work normally? Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
30-09-2013, 01:20 PM | #4 | ||
Yes, hazards work fine and fuses are all ok.
AU XLS. |
30-09-2013, 01:59 PM | #5 | ||
5.6L x 2 pilot
Strange. Never seen of heard of it before. Hopefully someone on here will know what is going on - hopefully something simple.
Stu
30-09-2013, 03:09 PM | #6 | ||
Au Falcon = Mr Reliable
Your bem fuse ok? The bem (body electronic module) is faulty if your hazards are working but not working from your key fob according to my ellery's manual. You probably need another matching bem to test & replace after eliminating faults from wiring to it (bem) if theres any. If your not too handy with the tools, a trip to the sparky may be in order. i hope someone with some more knowledge will chime in very soon for you, good luck!
cheers, Maka
30-09-2013, 04:38 PM | #7 | ||
Had a trailer on recently? Often I think faults occur when dodgy wiring is introduced to the trailer plug.
30-09-2013, 07:43 PM | #8 | ||
Only just bought the car. Was very cheap. I'll double check fuses again.
AU XLS. |
30-09-2013, 11:43 PM | #9 | ||
Hi. Is it still using ford remotes? seem a few cars of this age where people use cheap remote locking kits to drive the factory locks. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
01-10-2013, 07:24 PM | #10 | |||
Also cycles the lock about 3 times when i unlock the door and then again when i open the door.
AU XLS. |
