Old 09-09-2013, 01:04 PM   #1
bander91
Arrow XR5 front brakes into Zetec 2.0
Hey everyone,
I've got a August built 2005 Focus Zetec 2.0 duratec and its time for the front brakes to receive some loving. I was curious to know if there is much involved in swapping the zetec calipers and rotors out for XR5 Turbo ones.
Has anyone done this ?
Is it worth it ?
Anyone got some for sale ?
I've been told that I may have to change master cylinder to the Xr5 one aswell.
Thanks in advance.
bander91 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 08:58 PM   #2
leakey
leakey's Avatar
Default Re: XR5 front brakes into Zetec 2.0
Been thinking the same thing. There's a set on Ebay right now. (just the front calipers)
I cant see why not. Race ya to it!
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 10:28 PM   #3
DZFord
DZFord's Avatar
You might want to consider whether the caliper mounting bracket is the same for XR5 vs non-XR5
Old 11-09-2013, 09:37 AM   #4
bander91
Surely someone has done this before haha.
Would doing this mess with the abs ?
Old 11-09-2013, 09:48 AM   #5
Russ
Russ's Avatar
There's only one way to find out so get your spanners and sockets out
Old 11-09-2013, 08:14 PM   #6
bander91
Sounds like a plan. I'll be sure to do a proper write up when I do.
Old 12-09-2013, 10:54 AM   #7
brenx
brenx's Avatar
The only issue you make have is you may need new wheels if your rims don't fit over the calipers.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2013, 10:55 AM   #8
brenx
brenx's Avatar
No the abs system is universal in both cars.
Old 12-09-2013, 11:52 AM   #9
Russ
Russ's Avatar
18" XR5 T rims will sort that out
Old 12-09-2013, 12:35 PM   #10
bander91
I've got the 17" zectec alloys, hopefully they should clear the calipers.
If not its an excuse for Xr5T wheels.
Old 12-09-2013, 03:13 PM   #11
brenx
brenx's Avatar
Finding a set ain't easy. Need two for my mrs xr5. Hens teeth comes to mind.
Sent from my GT-I9300T using Tapatalk 4
Old 12-09-2013, 06:25 PM   #12
Russ
Russ's Avatar
There's usually a set or 2 floating around on fleabay - http://www.ebay.com.au/itm/18-WHEELS...-/130987231084
http://www.ebay.com.au/itm/FORD-FOCU...-/121174782770
You can expect to pay around $800 for a decent set of 4
Brenx, if you haven't already, have a look on the XR5Turbo forum that's where I picked up the set for my Zetec
Old 12-09-2013, 07:10 PM   #13
brenx
brenx's Avatar
The problem is you can get non gen wheels easy but there are differences between ls, lt and lv. We have an ls and lv xr5's. Non gens are known as snowfakes.
