Old 09-07-2013, 04:29 PM   #1
And04133411
Default Ford winsdor 5.8l injector problems
Hey guys! Having problems with my ford Windsor now :( it's a 5.8l efi engine, now what's happening is that the injectors are staying open and when I turn the ignition on fuel just pumps straight into the cylinders. Now the twist is that the injectors are just reconditioned as is the engine, also its just been converted from gas/petrol to just petrol. I got told that when it was on had sometimes they wired it up so that the injectors stayed open to keep the injectors cooler? Not sure if hats true or not but that would explain y and mayb the wiring is a bit mixed up.
And04133411 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2013, 07:19 PM   #2
sk8xr8
sliding by you...
sk8xr8's Avatar
Default Re: Ford winsdor 5.8l injector problems
is this in an f150?
G6E TURBO
Pedders extreme adjustable coilovers, whiteline adjustable swaybars, some bits from Herrod and some love from Bluepower racing developments...304 rwkw..
Just starting...!!
sk8xr8 is offline   Reply With Quote Multi-Quote with this Post
