Old 15-06-2013, 08:20 PM   #1
b055m4n
Default how to...
Hi guys hoping someone can tell me how to open the air filter box on the wifes 2008 fiesta I just know im going to break something...its not suppost be hard....lol help.
b055m4n is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 10:52 AM   #2
trumpy73
Default Re: how to...
if it's the same as WS then there should be 4 screws?
trumpy73 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 10:53 AM   #3
Fiesta God
Ford Fiesta
09 onwards Fiesta it's 4 hex screws, one on each corner ... not sure about the '08 (I would assume it's similar)?
2009 Ford Fiesta WS 1.6L Manual - 16" CSA Sword Machine Polished Wheels, Slotted DBA Rotors with TRW Brake Pads, K&N Air Filter, Tinted Windows ... and more to come
Fiesta God is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 05:40 PM   #4
vhcbm
having Fiesta withdrawals
vhcbm's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Ford couldn't fix my BlueTooth issue. This member posted a download link, with instruction, on how to do it myself. One week on, the unit hasn't played up once. Three different dealers told me to virtually 'Live with it.
WQ shape or WS shape? I think it was under the engine cover on the mk6 which should be just a few screws. Mk7 is four HEX screws. airbox is at the bottom right of the engine bay.
New: Ford Focus RS in Ultimate Green number 82/315
Past: 2009 Ford Fiesta LX in Vision Blue - Sold
vhcbm is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 06:31 PM   #5
b055m4n
Thumbs up Re: how to...
Ok thanks for the replies guys...I've worked it out, disconnect on right side air intake pipe and on left side disconnect air outlet to manifold pipe also right next to that is a 12mm fitting disconnect it from side of air box, then undo two I think 12mm bolts top of air box then with both hands on each side of air box pull firmly up and down air box sits on two metal studs with rubber plugs when out turn upside down and undo nine hex screws then air box will split in two exposing the filter....bloody easy when you know how.
