Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 04-05-2013, 03:40 PM   #1
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Default Can SCT flash tuner correct speedo ?
Chris / Theo
Do you know if the SCT handheld device can correct speedo error ?
GPS shows 100 - speedo on the GT shows 108.
Error varies from 5-8 klmh
There is a menu option in the SCT tuner for rear end ratio and revs per mile......would plugging in some data here fix the error or is the speed calculated from ABS sensor.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2013, 08:54 AM   #2
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Default Re: Can SCT flash tuner correct speedo ?
The best way to fix it is to run the car on the dyno @ 100klph and work backwards to the tune to correct it. This way it will be right on 100..
I don't think user settings has the functions for you to change yourself..
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2013, 10:13 AM   #3
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Thanks Guys
The SCT device allows for rear end ratio to be changed and also REVS per MILE input. I have put in the rear end ratio for the GT and also the REVS per MILE ( 783 ) based on the Tire calculator - here :
http://www.gordon-glasgow.org/tirecalc.html
I'm thinking maybe I should just reset the REVS per MILE back to factory setting ? I'm guessing it may not be correct as it may vary from tyre to tyre and how much air pressure and tread you have left ?
Old 06-05-2013, 03:42 PM   #4
Theo@BluePower
Bluepower
Jim,
depending upon the strategy it can be as simple as changing user available options, We dont normally leave these unlocked, sometimes the VSS source code needs to be changed to get this to work.
Hope you've been well mate
Chris
Bluepower website
03 9305 3000
Old 08-05-2013, 10:26 AM   #5
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Thanks Guys.....all fixed now
I reset the axle ratio in the SCT to "STOCK" - which I think turns it off.....
I then measured the actual rolling diameter of my rear tyre. 1 complete rotation = 78.5 inches.
There are 63,360 inches in 1 mile
So 63,360 divide by 78.5 = 807
Therefore - it ends up being 807 revs per mile.
When I used the online calculator to get the REVS per Mile :
It gave me 783 Revs per mile for a 245 / 35 / 19 tyre
So I think that's where the error was.
Driving to work this morning after the change - the Speedo now shows 80 and the GPS shows 79......much better. Previously - it was out by about 8klm/h at 90.
I wonder if the trans shift points are also altered by this ? If the car thought it was doing 80 - but it was actually only doing 72 - it would have been shifting early - right ?
Old 08-05-2013, 01:02 PM   #6
Bluepower
KenneBell Australia
Bluepower's Avatar
Usually Jim it does, depends on where the VSS is set, if its default (and I think yours is) then it is indeed one of the primary protocols for VSS, therefore tailshaft rpm, therefore shift speed.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 01:22 PM   #7
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Chris
Cool - OK
Learn something new everyday.
Hope you guys have been keeping well......
I'm trying to find all sorts of new reasons to come and visit you guys lately.....
