17-02-2013, 10:41 PM | #1 | ||
Hi All
Please see attached pic. milky.jpg My AU is using coolant still, rough idle at start up and know having major problems even starting the car. It is like it is still in gear. Have milky oil and some white smoke. I assume head has a hole in it but read a post on it could be the inlet manifold gasket? ANy ideas? CHeers Mick |
17-02-2013, 10:43 PM | #2 | ||
Just cruisin'
It will be a blown head gasket
17-02-2013, 11:02 PM | #3 | ||
Bugger
How much for a head to be replaced if anyone knows? I have changed heads on other cars before also. AT the wreckers they charge around $1000 for a low k motor to be fitted. Cheers Mick |
18-02-2013, 01:58 AM | #4 | ||
5.6L x 2 pilot
6 or 8 - will have a bearing on cost. It will probably be only a head gasket. I just did my 8 for about $400 in parts with my own labour.
Good luck Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
18-02-2013, 02:35 AM | #5 | ||
Hi
It's a 6, series one. I will get some quotes in the morning and post up a rough price for reference. Cheers Mick |
18-02-2013, 03:54 AM | #6 | ||
Is something like this an option?
I have not a clue abiut the risks on such purchase, tho. http://www.ebay.com.au/itm/AU2-AU3-X...item51a01a734b
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension -- ----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 ----- -------- Preventative Maintenance Policy -------- |
18-02-2013, 09:38 AM | #7 | ||
these engines are cheap from the wreckers as the rarely fail so they are plentiful you should get one for $1000 or less fitted or if you want to fit it about $200 to $300
[SIGPIC][/SIGPIC]
18-02-2013, 03:13 PM | #8 | ||
Au Falcon = Mr Reliable
G'day ZXTC, please check your transmission also, theres a chance milkshake has gotten in there also. I woudnt drive it till its cleaned & or repaired.
cheers, Maka
19-02-2013, 12:26 AM | #9 | ||
if it were milky in the coolant bottle it could be transmission but if the engine oil is milky it's the head
[SIGPIC][/SIGPIC]
3 users like this post: |
19-02-2013, 11:54 PM | #10 | ||
I would replace the whole engine, they're cheap, rarely fail, and the factory head gasket seal is the best you will ever get. MLS gaskets need a very clean flat surface to seal, and standard composite ones don't last very long on these engines (see E-series forum endless head gasket tails of woe).
20-02-2013, 12:20 AM | #11 | |||
5.6L x 2 pilot
If you are planning to hang on to your car for a while, my thoughts are to repair. For me, the unknown of what you may get, falls way short of knowing what you have got. Within reason of course. Stu
25-02-2013, 02:28 AM | #12 | ||
Hi Guys
Just a quick update. I used a bottle of this http://rislone.com.au/catalog/view/9...top-leak-41109 and i haven't lost any coolant and the oil is not milky anymore plus the car is starting and running much better. This has been for 5 days now plus a 280 km counrty trip. Will be interesting to see how long it lasts. Going to be upgrading the car in the next month or so, so fingers crossed. Cheers Mick |
26-02-2013, 03:32 AM | #13 | ||
And you've driven it 280kms? Brave boy. If it spills its guts entirely don't be surprised. ope its not all over any roads I drive on or your driveway.
26-02-2013, 09:19 AM | #14 | ||
Its not unknown for a headgasket repair in a bottle to last some kays it just depends on how bad the gasket has let go- at best it'll delay the inevitable for a little while so old mate can save some cash for the proper repair or get rid of the car as it is.
cheers, Maka
2 users like this post: |
26-02-2013, 11:25 AM | #16 | |||
depends where the gasket is gone, if it is only between an oil and water gallery these repairs can last a long time but if the leak also involves the pressure of the cylinder it generally won't last long at all. technology has come a long way from the old bars leaks days , modern leak repair formulas are quite good
[SIGPIC][/SIGPIC]
27-02-2013, 12:44 AM | #17 | ||
Will keep everyone updated on how this goes.
Plan is to upgrade my car then fix or sell as is. I also drive 60 kms a day to work and back so all good at this stage. Just buys some more time to look for another car. Not much around atm. Cheers Mick |
27-02-2013, 01:51 AM | #18 | |||
5.6L x 2 pilot
Stu
