Old 26-01-2013, 12:20 AM   #1
DAVEROX351
Default 1990 Laser headlight and indicator problem
I just bought my daughter a 1990 laser. She took it for a drive the other night and said that when she indicated left the lights would flash to high beam. Any ideas before I start pulling things apart. Thanks
DAVEROX351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 08:27 AM   #2
Russ
Russ's Avatar
Default Re: 1990 Laser headlight and indicator problem
I have seen people flash the lights accidentally when putting on an indicator, sure she didn't do this as well ? You may have to try it for yourself first and see if it does do it and if so try cleaning all the wiring plugs to headlights and indicators, then check the relays, next guess will be there's a fault in the indicator / headlight stalk on the steering column (from memory that's where it's located)
Old 27-01-2013, 09:06 PM   #3
DAVEROX351
No worries. Will take it for a drive and check myself. If it is still doing it I will probably clean all connectors etc . Cheers
Old 30-01-2013, 04:26 PM   #4
graham7773
replace the combination switch with a known good one. Lasers and Telstars are known for this fault. In the AX Telstar there is a small module in the switch you can replace. It is held in with 2 screws. I am not sure if the Laser is the same. Possibly, as they come out of the same factory.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
