I am hoping someone can give me some advice cause I am pretty much at my wits end!
I have a 1999 AU Fairmont 5.0L and there is an issue with regards to the transmission. When first driven from cold the car drives absolutely fine however after about 15-20mins of driving the problem starts. Once warmed up the car seems to rev out higher in first gear and then the car jumps into another gear, which to me seems like 3rd and not 2nd gear. This only happens when going from 1st gear, all other gear changes seem ok. I took it to my usual mechaninc and he looked at it an advised that it was actually a miss fire which was causing the issue with the transmission so I had new plugs, leads, cam shaft sensor etc.. changed to fix the miss fire. Obviously the mechanic never drove the car for any period of time as when I drove it the following day after a while the same problem was still happening. I took the car back to the mechanic and he had advised that the problem is being caused by a faulty radiator which is leaking fluid into the transmission however he has also said that the transmission also needs replacing. As the car drives fine when cold I am a little baffled that the transmission would need replacing however not being a mechanic I am only going on guess work? I am interested if anyone has come across this problem or has any advice on what the problem may be, I would be greatly appreciative of suggestions. Cheers, Dan |
Au Falcon = Mr Reliable
If the mechanic said the radiator is faulty & leaking coolant into the transmission, unfortunately your up *&^% creek! You have to confirm his advice somehow while NOT driving the car.... look in the coolant tank & check the colour/condition of the coolant - is it mixed with red transmission fluid? Check the link & go from there. Good luck with it
http://www.ehow.com/how_5031298_chec...ion-fluid.html cheers, Maka
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Your mechanic doesn't seem to be able to make up his mind. l would be taking it to a trans specialist asap for a diagnosis. It may be as simple as needing a flush and service.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Definitely use a specialist. Suggest you dont use a non-specialist like I did initially and it cost me $1000 for the first effort, then another $1800ish to get it right. Big lesson learned.
This sounds exactly the same as the issue I was having in my EL Ghia.
The problem was the S5 solenoid and it is easy to fix - definitely worth trying at least. Drop the pan, lower the valvebody, remove the S5 (largest solenoid) & replace. I got a new S5 for $100 and it took me about 2 hours to do the job but I was being very,very cautious. Of course I went to 3 transmission places first and all insisted that I needed a total recon. 12 months on it is shifting like new. |
#6 | |||
PETER logged as Millview
A spark plug affecting the Auto Trans , A leaking radiator affecting the Trans What about a dead fly on the Windscreen creating a miss in the Engine Or a full ash tray meaning you need a new Car . Come you blokes get some proper advice when you need it , ask a Mate or at least someone that knows something about cars . Jeez I wish I was young enough and still be working as a Mechanic I would make a fortune except for the fact that I could not lie enough to sound real .WAKE UP YOU BLOKES.
Only 76 yrs young and Navy Veteran First ride :- Mk2 Zephyr , XA falcon , ZH Fairlane , now 5ltr V8 AU Fairlane on dual fuel ,AU Forte on Petrol Longreach XH ute on Dual Fuel In great condition and picked it up for $1500.00 when wrongly price listed on Gumtreel |
5.6L x 2 pilot
Who are you telling to wake up? Maybe some keyboard warriors should think before the run off at the fingers? Th advice given is valid, just because I didn't comment on the rediculous nature of the claims from the mechanic doesn't mean I need to wake up.
Not sure when you where a mechanic, but I am not a mechanic and know that in factory form, the auto trans fluid runs through the radiator for cooling. A leaking radiator in our AUs could in fact fill the trans with water. This forum member was a obviously concerned and is also not a mechanic. Advice can be given without insulting people. That is the benefit of the forums. Awake, Stu
#8 | |||
![]() http://showmoreresultsfromwww.fordfo...php?t=11300773 cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 17-01-2013 at 05:56 PM. |
