Old 08-12-2012, 06:31 PM   #1
jt-1994
Default rough and shakey idle
Hey guys my au has a really annoying idle as it isnt smooth and shakes the whole car isnt smooth till 2500rpm, normal driving is fine. I replaced the inlet manifold gasket as i thought it would fix it but the rough idle still persists. Ive also replaced the o2 sensor, fuel filter, plugs and leads, cleaned throttle body and isc valve, reset ecu, checked fuel pressure regulator as it is also using alot of fuel around 12L/100 on the freeway sorry for the long post any help would be greatly appreciated
jt-1994 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2012, 07:22 PM   #2
2002au
Define definitive
2002au's Avatar
Default Re: rough and shakey idle
Try changing the pcv in the rocker cover. Around $10 from ford
BF F6 TYPHOON in NEO #718 ~ 356rwkw :
BF XR6 TURBO in SILHOUETTE
2002au is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2012, 07:45 PM   #3
jt-1994
yeh ive already tried that aswell im thinking coil pack or injectors maybe?
Old 18-12-2012, 09:39 AM   #4
Maka
Au Falcon = Mr Reliable
Maka's Avatar
G'day there, get a ecu scan & see what codes it throws- could be coilpack?
cheers, Maka
Old 19-12-2012, 08:10 PM   #5
mikeeman_ford
EXR-699
mikeeman_ford's Avatar
If you can do the ECU scan that will definatley give you the answer.
My car, the problem was Cam Angle sensor
Go Pedal = Fun Pedal
AU XR8 Tickford 200kw
Visit my Blog lovemyfalc.blogspot.com
RIP - AU1 1999 XR6 VCT, Forever in my heart.
mikeeman_ford is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 11:20 PM   #6
jt-1994
Thanks for all the suggestions ive searched for error codes but the only one that came up was malfunctioning vehicle speed sensor, once i cleared it and went for a drive it didnt reappear. Im going to replace the coilpack and see what happens
