Old 07-12-2012, 03:23 PM   #1
walter351
Default Urgent help car wont start
g'day everyone im in need of some urgent help, my brothers xr6 which is an 01, duel fuel wont start, here are what the problems/ things leading upto it
starting yesterday the car backfired
today the car would drive ok on lpg but when switch over to petrol the car was underpowered, rough idle, then just clonked out and now can not get the car to start again. The has plenty of fuel and gas, i think being duel fuel it also needs petrol to start but even on gas can not get it to start.
checked leads and few things, but not to sure, maybe a blocked fuel filter?
really need help asap
walter351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2012, 03:25 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Urgent help car wont start
it's possibly blown a vacuum line off, at the rear of the intake manifold?
can you hear the fuel pump prime for a second or so when the ignition is turned on?
and yeah if it hasnt been changed in the last few services, the fuel filter might be blocked?
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2012, 03:28 PM   #3
walter351
im not to sure about the fuel pump prime what kind of sound should i be looking for, the car is about 15 mins from my house atm
the car drove after the backfire with one of the hoses blown off wouldnt it be making a sucking sound also??? i did check the initial hoses but seemed they where all on
Old 07-12-2012, 03:48 PM   #4
walter351
if i open the fuel cap and listen while the key is turned to the point just before you crank it should i be able to hear the fuel pump buzzing???
Old 07-12-2012, 03:55 PM   #5
walter351
reading this i think the pump has **** itself as he always runs it with the fuel on red and near empty
http://www.fordforums.com.au/showthread.php?t=11239924
Old 07-12-2012, 04:01 PM   #6
walter351
and just confirming too there is no mrrrrrr sound when you first hop in the car, so im gonna go double check now but yeah fuel pump went poop
