Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 01-11-2012, 11:03 PM   #1
05_ENFORCER
05_ENFORCER's Avatar
Default Brembo Shuddering
Hi Matt, I was gonna send you a PM but thought I'd get it out in here.
2012 FG GT MK2 6/4 Genuine FPV Brembo's shuddering at low, almost parking speed, enough to make you say a swear word.
Very occasionally, not all the time, hot or cold, very random.
Any ideas?
Brembo pads leaving deposits??
I am at a loss for an explanation.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2012, 03:10 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Brembo Shuddering
Any ideas?
Possible control arm bushes worn as this was very common when they first came out and they don't look worn but being fluid filled they don't cope well with the big brembo stopping power. The complaint from memory was the shuddering and sometimes felt like the ABS was coming on. There should be a few threads on this on the forum.Let me kow how you go.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 02-11-2012, 04:37 PM   #3
05_ENFORCER
Thanks Matt, definately not the bushes, she's only done 4500 klms
I can see the front wear marks looks as if only 80% of the pad is being used.
Possible bed in issue?
I guess the only way to rectify is to skim and re-pad if this was the case?
Old 02-11-2012, 06:35 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
We had FG owners with less km's and having the same issue.I can't say 100% this is your problem without an inspection but it was an issue. See how you go with the bedding in but 4500 klms is enough bedding in time.
Some customers would only feel it on the left side to start with but it only got worse and customers taking there cars back to Ford didn't believe it either at first. The nolathane bushes fixed the issue.
Read this i hope the link works
http://www.fordforums.com.au/showthr...ght=FG+SHUDDER
MATTHEW PEARCE
Phone 02 9609 1101
Old 04-11-2012, 03:30 PM   #5
kempy311
BEN
kempy311's Avatar
When I had shudder it was very violent when low speed cornering also pulling into a drive ways but it didn't always do it like stated above almost like abs coming in. Turned out to be the upper inner control arm bushes.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2012, 12:24 AM   #6
Phildo
Phildo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent work on the BF Brake information. Technical Contributor: For members who share their technical expertise. - Issue reason: Photo Essay - Centre Console Disassembly
Are all the contact surfaces clean?
http://www.fordforums.com.au/showpos...74&postcount=9
I remove the studs from the hub plate and go nuts with an electric drill and wire brush:
This.
Wasn't this a recurring issue, and Ford ended up releasing/fitting an updated upper control arm bush?
Would be worth looking through the FG problems thread: http://www.fordforums.com.au/showthread.php?t=11224789
Click here for my previous Photo Essays and Build Threads.
Good people. Bad people. Smart people. Dumb people. Car crashes. Vomit.
Read about it all at Cabloid, the web site that has stories and photos about my life driving a taxi at night.
www.cabloid.com.au
Phildo is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2012, 12:31 AM   #7
kempy311
BEN
kempy311's Avatar
Originally Posted by Phildo View Post
This.
No idea because mine didn't originally come with brembos so I didn't notice the problem till after they were put on.
331rwkw.
