Old 04-09-2012, 08:32 AM   #1
laurencelr1
Default EA MPI engine into a EA CPI car won't fire help
Hey guys I own a EA falcon and on the weekend I pulled out the old CPI engine and put a EB XR6 in it. It turns over but won't fire. I think all the hoses and wires are in the correct place but I'm not sure plus ive got a few hoses left over.
Can someone that has done this conversion or another MPI engine in a CPI car please help
laurencelr1 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 09:26 AM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
Default Re: EA MPI engine into a EA CPI car won't fire help
one question I have for you
what dizzy did you use did you use the one of the CPI or the one of the MPI as they are different internally
there is a metal plate/disc in them that has from memory one has 3 tabs on it the other has one tab (cfi)
it was the problem i had when i attempted my changeover years ago
Jason
[SIGPIC][/SIGPIC]
Old 04-09-2012, 09:56 AM   #3
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Did you change the ECU? I think the wiring is different somewhere too...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 10:03 AM   #4
FPV414
FPV414's Avatar
You need to tell us whether you're missing spark or fuel.
You need to change the ECU, fuel pump and distributor along with the more obvious stuff.
There may also be a single pink wire floating around near the ISC which you need to tap on to the tacho signal wire off the main loom if you haven't already.
FPV414 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 11:31 AM   #5
laurencelr1
Im using the distributor that came with the XR and I changed the ECU which didn't do anything havnt seen a pink wire yet
Old 04-09-2012, 11:36 AM   #6
laurencelr1
There is fuel but no spark
Old 04-09-2012, 11:39 AM   #7
IceValk85
MY2010 SV6 SIDI -Black-
dead dizzy?
IceValk85 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 12:22 PM   #8
laurencelr1
I dunno yet it looks alright
Old 04-09-2012, 01:47 PM   #9
FPV414
FPV414's Avatar
Did you use the inlet manifold loom from whatever XR motor you put in the car?
Was the ECU a Smartlock one? If it's a Smartlock ECU then there's your first problem.
What year and series is your EA? And what year/series is the EB XR loom?
Old 04-09-2012, 02:34 PM   #10
laurencelr1
Yer I used the inlet manifold that came withe the XR. The ECU was out of another 5 speed EA. The EA is an 89 and the EB XR6 is a 93
Old 04-09-2012, 06:58 PM   #11
last fairlane
last fairlane's Avatar
Cool Re: EA MPI engine into a EA CPI car won't fire help
Like FPV said about the smart lock
there should be 2 green wires thats is the smart lock I had trouble firing a Windsor 5 litre but when I joined the two greens together it fired
just a thought
John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 07:01 PM   #12
laurencelr1
It's a normal ECU. Could it be a wiring problem?
Old 04-09-2012, 07:12 PM   #13
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Smart lock would not allow the engine to turn over though.
Do you have spark at the coil?
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2012, 07:19 PM   #14
laurencelr1
I dunno I havnt checked. I pulled one of the spark plugs out, put the plug lead on it, sat on top of the engine to see it spark and turned the engine over and I couldn't see any spark
Old 04-09-2012, 08:34 PM   #15
FPV414
FPV414's Avatar
Change the loom in the manifold to an EA one just to be safe, and try get one around the same year and series as your EA. I think there could be differences in the EB one that may be causing your dramas. If you don't have wiring knowledge this would be the easiest way to go.
I am placing bets on the coil -ve wiring being out of whack somewhere. This is usually the issue.
Old 04-09-2012, 08:36 PM   #16
laurencelr1
Ok then. What's the option if I have wiring knowledge?
Old 04-09-2012, 09:07 PM   #17
Simple6
Simple6's Avatar
Well you can test if you have spark at the coil by arcing the lead between the coil and dizzy cap to the block while turning over the engine.
*Note - doing that can be dangerous! Electricity hurts. Don't do if you're not comfortable.
Old 04-09-2012, 09:57 PM   #18
laurencelr1
I'm comfortable doing anything being an apprentice mechanic. Just wish I was more experienced so I could have got it right
