'mechanically-challenged'
I'm getting sick of the look of my aftermarket headlights and want to go back to stock, but with painted bezels to match the grille. At this stage I want black lights to match the black grille which i just repainted recently, but am also considering blue grille/headlights. Can anyone with photoshop skills mock up these combos for me please?
These are the aftermarket headlights. ![]() Anyhow, yesterday I took my old stock headlights apart using the 'how to' in the 'useful threads thread' and managed to get the headlight surrounds/bezels out. Unfortunately I cracked both inside indicator lenses in doing so ![]() So, I will have to buy another pair of stock headlights (mine were in crap condition anyway and didn't have any of the wiring attached), and then get a professional to take them apart, put the painted bezels in them then put them back together and fit them up. Would a panel beater be best to take them to to do that job? How much you guys reckon it'll set me back? Will probably paint the bezels myself to save money. Anyhow, some pics: Headlight surround inserts/bezels ![]() ![]() Cracked indicator lenses ![]() ![]() ![]() Any help/info/photoshop mock ups would be greatly appreciated. Cheers, Chris
sirchAU's Galaxy Blue Falcon S
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I did mine
![]() and ![]() and ![]() Mind you I had a chrome bezel not the type you have. Heat the glue and pull slowly apart, be carful not to touch the chrome on the reflector, paint ( I used matt black) and re seal with skikaflex. UK
I had mine done by a bloke called Scott at the Headlight Hospital (in Doveton), cost me $120 to get them both done, plus I provided the colour matched paint in a rattle can (from Autobarn) to get them in sparkling burgundy.
This was back in 2007 mind you, so the price may be off, but he still comes up in the Yellow Pages if you don't want to do it yourself. Cheers, Matt |
#4 | |||
That headlight joint has closed hasn't it? I seem to remember something about a fire through the place a while back. However there is another place somewhere in Melbourne that do it so I've heard. It's posted on the forum - maybe you could get lucky with the search function - it never seems to do anything for me! LOL. I've pulled a few of my own apart - not too hard if you have a heat gun and a ton of patience.
Manged to get mine apart with a hairdryer... what a PITA! Pity I broke the plastic indicator lenses on both sides though, won't find replacements without buying the whole headlight. Mine were in crap condition anyway I guess so will find another set from a wrecker and get the painted inserts put in. Might have another go at it, now that I've done it once the 2nd time should be easier.
Search function is a bit hit and miss for me too it seems, always end up trawling thru a million different posts to find what I'm looking for!
I was goign to do a how to from what I did. Take your time and don't rushs I had 6 light I got cheap, and put the best bits together. Check the 2nd hand lights very carefully for cracks, scratches on the plastic lens and the back.
UK
[AUT-747]
I'm really interested in having this done professionally also. anybody know somebody who is willing to do the job? Im in melbourne too if that helps.
cheers. |
Finally got around to doing a how to for lights.
http://www.fordforums.com.au/showthr...15#post4435515 UK
I remember seeing that guide from MADNC_8 and JC too, yours is a great job as always mate.
Btw, you wouldn't happen to have a few of those old spare headlight bits still lying around would you...? I'm after the indicator lenses, in particular the RH front, but a L/R pair in decent (uncracked) condition would save me buying a whole new set of headlights. Will cover the cost of postage to VIC 3802 if you do have them? PM me if you can help mate. Cheers, Chris
T-Series Club Member Vic
One thing I'd suggest - don't use Sikkaflex to reseal your lights unless you are happy to never be able to get them open again.
I used some Butyl rubber roll used to seal windscreens (from alibaba). It's super easy to use as you simply need to stretch it out as you lay it in the groove. The hard part is removing the old rubber with a heatgun...though lots of people don't bother, they just reheat the old rubber and squeeze them back together with generally no leak results. One of my lights already leaked and I was keen to do it only once, hence the extra effort. |
#12 | |||
UK
Thanks Ken, all good mate.
![]() Put my one good headlight back together yesterday. Seems putting it back together is much easier than taking it apart. Ended up just reheating the rubber adhesive that was in the channel and using it again, as well as a bit of extra black Silastic sealant I had lying around. Hopefully it is sealed well enough to keep the leaks out, I made sure to be very thorough. The indicator lens on this one wasn't too badly cracked and still clipped in nice and tight. Unfortunately the other one is stuffed... as well as the cracked indicator lens, it's outer casing is scratched and chipped, and some goose put fingerprints all over the reflector (ooops!). Definitely time for a new one. Anyone got a spare RH side headlight in good condition for cheap??
#14 | |||
Stay Classy ™
#15 | |||
UK
#16 | |||
Uk
#17 | ||
reminds me of my old ones on the work ute ... with projectors.
#18 | ||
I remember those !
UK
#19 | |||
#20 | |||
Stay Classy ™
#21 | ||
I swapped them with HLC. When i traded the ute in ... and I think he ran HIDs behind them afterwards ... not sure if he kept them or on-sold them with his AU after he moved to Perth.
These were done by the Headlight Hospital ... and picked them up in Melbourne from The Doc when the masive AU meet was on several years back. They utilised NC Fairlane projectors ... they were OK ... but there's gotta be better units out there now. I was only using halogen in them. I have a few beam shots against walls and stuff ... they did provide a flatter beam and seemed better coverage-wise than the standard reflectors .... but the main lighting was in the centre and you could tell ... brightness waned as it spread out to the edges ... the centres were more of a hot spot .... and I think this is the same for EF/EL XR projectors. SilverT2TE50 .... I like the shrouds on yours ... got some beam shots???
#22 | ||
Some beam pics.
![]() I had highbeam sorted though ... Lightforce 240s ... I used to live in a rural area ![]() ![]() ![]() ![]()
#23 | ||
Damn I miss that ute ... many a good time in it.
#24 | |||
![]() UK
#25 | |||
The below pic are the same setup, although they are LHD and I don't have them aimed the same way as this person has done. Mine are set to the same height each side with a couple of degrees tilt away from oncoming traffic (I'd not bother with this again). ![]() Once you've had HID in projectors, there's no going back that's for sure... |
#26 | |||
I can totally understand that.
#27 | |||
I had more open roads to enjoy in it ... played with it more than the BF too. Overloaded it many times ... and it still came back for more. Was just a shame it came to a point where it kept overheating .... even after replacing everything in the cooling system .... it was frustrating ... and I needed a ute to work. Shame really ... if it wasn't for that ... I would have kept it for a lot longer. Was funny getting guys at loading docks ask why I was driving a V8 as a courier ... that Stg 2 cam sounded nice at idle at running temp ... had a lovely lope to it and it rocked the ute side to side. Ahhhhh memories.
#28 | ||
[AUT-747]
anyone know of somebody who would be professionally able to modify AU headlights with a projector or something ? very interested to change my headlights they are just too stock !
cheers. |
#29 | |||
On your rig, I'd try body colour painted inserts and chrome shrouds, probably the same style as mine (Porsche Cayenne Turbo 'inspired') as its hard to find anything else that suits the big AU lamps. He can fit halos to them if you like that look. He's also done coloured LED parkers behind the projector which look amazing and sure will fix those 'stock looking blues' that you have! Al |
#30 | ||
Glenn's old AY002 had body coloured trim pieces in side his headlights .... I think his colour was Sparkling Burgundy ... it looked awesome. Much better than black would look.
Sorry ... Regency Red he had: ![]()
