Old 28-08-2012, 08:29 PM   #1
taybelZ
Default VIC - Ford focus interior light fuse
Gents, I've got a LT focus and the interior light isn't working after trying to replace it with a ebay LED light.
Suspect the fuse is blown, got to the fuse box under the glovebox but it looks nothing like what is in the LT focus manual provided.
The manual has reference to a box something simular to this:
http://www.google.com.au/imgres?um=1...9,r:0,s:0,i:73
Though mine is not like that at all...
Anyone else had a simular problem?
taybelZ is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 10:38 PM   #2
Russ
Russ's Avatar
Default Re: VIC - Ford focus interior light fuse
If you have electric mirrors check and see if they're still working. I came across a post on another forum where the OP was saying similar to you in that the fuse box looks nothing like what's in the manual. They had also replaced globes and blown a fuse (this should always be done with the interior light switched off) I'm not 100% certain which model this was on but they said they replaced fuse # 35 (7.5 amp) and issue was resolved. Hope this may be of some help to you
Old 29-08-2012, 01:49 PM   #3
Marlboro2728
Marlboro2728's Avatar
If it is a LED, try and swap how it goes in. This will reverse the polarity. Done this once before!
Marlboro2728 is offline   Reply With Quote Multi-Quote with this Post
