Old 08-07-2012, 10:03 PM   #1
efv8
Tyre Fitter
efv8's Avatar
Talking EB engine into te/tf cortina
being fuel injected, does the conversion need to hav an engineers cert? putting the running gear in is the easy part for me, whats the best way to go about the wiring, ecu etc? feed the eb wiring loom into the corty or just pay someone to wire the ecu in to save having all the extra wiring hanging around? and would i just block the extra vaccuum hoses?
efv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2012, 10:48 AM   #2
Kevaclone
Kevaclone's Avatar
Default Re: EB engine into te/tf cortina
have you checked the engine clearance for the bonnet? OHC engine may be a bit higher than the older crossflow, and even these had very minimal clearance in the Cortina
The wiring would need the loom from the EB run through the car,
Do you need to include the key and ignition with the ECU on this engine?
Extra vacuum hoses?
03 BA XLS 6cyl Ute-Mercury Silver
04 Subaru Liberty GT Premium
99 Toyota 105 series Cruiser TD
99 5.8M Profish plate alloy carport decoration
Kevaclone is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2012, 12:49 PM   #3
ebxr8boy
Regarding the wiring/ecu part of the conversion. If its manual then conversion is easy. Auto requires a little more attention with the wiring
You dont need the whole loom just the the engine & ecu harness
RIP - EB XR8 5spd - 168rwkw 400nm - Explorer Manifold, Phenolic spacer, K&N panel, U/D pulleys, 65mm Throttle, STD maf, ported E7's, Extractors, STD cats, STD exhaust no mufflers, AU snorkel, EF/EL Thermo's, unknown cam
14.6 @ 95 before Explorer Manifold and spacer
Daily - 4.0T Econovan
New project - 5.4l 331ci GT45, 8.2 4.125 Man o war, Billet LAE crank, Jon Kaase Heads, Pauter Rods, Diamond pistons, C6 Auto
ebxr8boy is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2012, 08:20 PM   #4
efv8
Tyre Fitter
efv8's Avatar
cheers guys. i have no problems in modifying the engine mounts or bonnet for clearance if need be. so the best thing would to have a complete donor car yeah? i think there is a place that does harness conversions. to put the eb harness in, i would have to take the cortina harness out wouldnt i?
Old 15-07-2012, 08:51 PM   #5
wodahs
wodahs's Avatar
Originally Posted by efv8
does the conversion need to hav an engineers cert??
modifiying engine mounts may need engineers cert
engineers cert usually needed for strucural differencs but some companies sell modified mounts that are already certified
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
