16-05-2012, 07:36 PM | #1 | ||
Hi
My manual WT has got this issue when im parking and changing gears between 1st & reverse (vice versa) the car will suddenly blip the revs up to about 2k rpm. At first i thought my fat foot was doing this but i think its the car. It happens cold and warm and usually when i pop the clutch in. Is anyone else getting this? |
17-05-2012, 10:25 AM | #2 | ||
No....
18-05-2012, 09:12 AM | #3 | ||
Da Shifty One
Yep im getting this when i go into reverse. I have no idea why it does it. I also have a WT
19-05-2012, 01:17 PM | #4 | ||
I got my first service in a couple of weeks hope they can sort it out
20-05-2012, 06:40 PM | #5 | ||
Very strange. My WT does not do this. Manual too.
07-06-2013, 06:46 PM | #6 | |||
I have just purchased a 2013 Fiesta CL Manual and noticed this rev issue as well, as soon as I depress the clutch when out of reverse gear and sometimes from switching from first to second. Has it been resolved? What I find weird is that it seems to be very "controlled", ie out of reverse gear, when it does, its always revving till 2000. When on first to second, a little below that. Ford dealer called me as an after sales service and I told him about this phenomenon, but he seemed like he never heard of this issue. I came to the conclusion that it could be some sort of "hill assisted' driving, as it does it most time on slightly uneven roads or driveways. My automatic jazz revs the engine by itself when it goes uphill, so for manual it maybe doing it on the neutral/clutch depressed position for faster gear change?? Please help, as I haven't got much free time, driving it into my dealership for checkup. Thank you |
11-06-2013, 10:45 AM | #7 | ||
mine did this too a Sep'12 build, reversed out of an awkward driveway and when i pressed in the clutch it revved up and stayed there for a few seconds, enough time to realise it wasn't me touching the acc pedal.
its only done it once but i think it went to about 4000rpm.
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
11-06-2013, 03:10 PM | #8 | |||
But since the clutch is already depressed, there must be some sort of sensor problem? Can anyone else help out? This car is poorly documented and most have received no help from their service center from what I have read so far. Thanks |
11-06-2013, 03:23 PM | #9 | ||
I have never experienced mine doing this. sometimes it makes minor adjustments, like gives it a few more revs if i dont give it enough. but we are talking 100rpm. (no not 1000).
on a quick side note, when you are all driving along (manuals) go for a gear change up, do you notice the revs hang for ages. if you hold the clutch in like a extremely slow gear change, the revs will very slowly fall and eventually match the revs for your next gear.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
11-06-2013, 05:32 PM | #10 | |||
Guess a visit to the service center myself is inevitable. Will post back once I have been given an explanation. Thanks
Ford Fiesta WT 2013 - Manual Chilli Orange |
11-06-2013, 06:11 PM | #11 | |||
Although over 32,000 kms i have never experienced the reversing revving quite a few people are experiencing. Any chance of a video on it by anyone? I cant imagine its normal, why would you want the car to be revving so high while reversing. Fair enough putting a sort of anti stall program in to make life easier. But the whole point of a manual is your managing revs and clutch by yourself.
11-06-2013, 09:14 PM | #12 | ||
I have taken the car to the Ford dealer twice and both times they explained as the throttle being drive by wire and the car over compensating for the dip in revs when the clutch is being engaged and disengaged. Only believe a small part of this explanation but other than this being annoying its not that major.
11-06-2013, 09:40 PM | #13 | |||
No point really, unless I want to skip the break and push straight into first to utilise the high engine rev. Maybe I just switch gear too eagerly and should try the suggested 3 seconds wait from first to reverse, as outlined in the manual. Just never had that problem, or maybe feature, in other manual cars before. Thanks for replying Trinhy, I'll let you know what my service centre tells me.
11-06-2013, 10:26 PM | #14 | ||
having Fiesta withdrawals
Strange how the WS doesn't seem to do it. Still the same gearbox, engine etc. Maybe it has to do with the tune, that's about all that could possibly be different. Similar to the cold start issue unique to the WS and older models but not WT.
New: Ford Focus RS in Ultimate Green number 82/315 Past: 2009 Ford Fiesta LX in Vision Blue - Sold |
