27-04-2012, 07:15 PM | #1 | ||
Hi all,
RaceTune in WA are pricing up a recond engine for my RS2000 and I wanted to know what additional bolt on mods I should ask for? Cams, Holley (or 2) with trumpets? I don't know what else can be bolted on but it already has PaceMaker extractors and a 2.25" exhaust. These are subject to availability at RaceTune or on these forums or eBay and if I can get them in time to be installed. Also what have people paid for a recond engine, fitted? Regards, Tom |
27-04-2012, 07:58 PM | #2 | ||
What do you want out of the engine? Drivable? Grumpy? Street/track?
Head conversion? If using the standard head, get it converted to run ULP. With my old motor, ended up fitting a high volume oil pump, and dual valve springs (cam had a lot of lift). Twin webbers sounded good, but drank like a fish. would also look for electronic ignition if not already fitted.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
27-04-2012, 09:35 PM | #3 | ||
I just want a bit more power and it to be drivable, if the cam meant it would be very lumpy at idle then I wouldn't bother but. I am not going to use it on the track and it will be much of a weekend car so the noise the engine makes is priority.... So webers are on the cards.
The car runs on unleaded already, I had another Escort which needed lead replacement fluid. EDIT: oh, wait, new engine so it might not run on ULP, Iwill have to ask when they call me back. |
03-05-2012, 03:50 PM | #4 | ||
Race Tune in Beechboro have gotten back to me with a price of $3k to put in a recond engine. Extra for a water pump and the other mods I wanted.
I could either do that or fix the bottom end (which is why I opted for the recond engine) and steering (which wobbles when turning either direction) Does anyone want to buy a white MKII RS2000 needing the above work for $4k? |
03-05-2012, 04:56 PM | #5 | ||
2 door or 4 door?
WA is probably a bit far for me.
03-05-2012, 10:09 PM | #6 | ||
WOGBOY69
Were You Live Bud
03-05-2012, 10:57 PM | #7 | |||
04-05-2012, 01:04 PM | #8 | ||
I live NoR in Perth. As for a picture, I have none on my laptop but it is my cover photo on facebook, lol. here's a screnshot
